ClearPass multiple Captive Portal; each with different certificate
  • 1.  ClearPass multiple Captive Portal; each with different certificate
    Posted Oct 12, 2016 06:22 PM
    Dear Members,
    We'd like to use ClearPass as an AAA server hosting many Captive Portals.
    Is it possible to configure ClearPass to handle Captive Portals in the following way:
    - each Captive Portal has an own certificate, so when a guest is trying to connect on SITE A, he/she will be redirected to the Captive Portal which has a cert from company A, and when a guest is trying to connect on SITE B, he/she will be redirected to the Captive Portal which has a cert from company B.
    I've heard that apache is capable of doing something like that, is it possible in ClearPass as well?
    Thank you for your answer in advance.
    Br.
  • 2.  RE: ClearPass multiple Captive Portal; each with different certificate
    Posted Oct 12, 2016 06:25 PM
    You'd have to put all of the FQDNs as subject alternative names in your web
    certificate.
  • 3.  RE: ClearPass multiple Captive Portal; each with different certificate
    Posted Oct 12, 2016 09:52 PM
    It cannot host a cert per captive portal but you can use either wildcard cert or one cert different SAN
