last person joined: 7 hours ago
Clearpass multiple https certificates
  • 1.  Clearpass multiple https certificates
    Posted Jun 27, 2016 04:22 AM
    Is it possible to have multiple https certificates on clearpass servers?
    Guests will be approaching the web portal with a URL from an external dns. Sponsors will be granting or denying access with a URL from an internal dns. To bypass the certificate warning, we'd like to add a second https certificate but don't know if it's possible.
    Kind regards
  • 2.  RE: Clearpass multiple https certificates
    Posted Jun 27, 2016 04:26 AM
    No, you cannot. You can, however, use a SAN certificate with multiple names.
  • 3.  RE: Clearpass multiple https certificates
    Posted Jun 27, 2016 04:44 AM
    I feared as much when going through the certificate tab in clearpass.
    Thanks for the quick reply!
  • 4.  RE: Clearpass multiple https certificates
    MVP
    Posted Jun 27, 2016 06:47 AM
    The best solution would be to use SAN or configure your DNS with split horizon where you can use different views to give different ip's back depending from which sunmet the request came.
  • 5.  RE: Clearpass multiple https certificates
    Posted Jun 27, 2016 07:00 AM
    Mmmh, might be worth considering. Thanks!
