Hey Hatzo, you're welcome.
This approach means you have more queries in the role mapping, but you can easily save the VLANs in the network device.
The advantage is that the enforcement profiles do not have to be changed.
Post your result, whether it works or not, or if you need some help.
Waldemar
ACCX # 1377, ACEP, ACX - Network Security
Original Message:
Sent: Feb 21, 2024 03:39 AM
Subject: Clearpass multiple vlan role mapping
Seems like a feasible solution. I'll give it a try.
Many thanks Waldemar
Original Message:
Sent: Feb 20, 2024 01:31 PM
Another option is to save the VLAN name in a user-defined attribute in the network device. It's neither right nor wrong, the approach just has to fit your requirements.
In first step you create a device attribute called Data-VLAN.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/a4ee9c2bd1cc416f9fff55aaf5558706.png)
If you need to overwrite the normally assigned VLAN for a switch, create the Attibut in the network device and set the corresponding value. You can access the Attribute-Value by entering the attribute-name prefixed with % and enclosed in curly braces, also %{Device:Data-VLAN}.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/3536d8001b094d3099fad73157714922.png)
Now you check in rolemapping or in enforcement whether Device:Data-VLAN exists. If not, set the normally assigned VLAN. if it does exist, set the value of the Device:Data-VLAN attribute.
The enforcement profile would then look like this:
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/5c52d6ce2cfd410a8e90f7c8f1685f2e.png)
This gives you flexibility and allows you to set a different access VLAN for each switch if required.
Waldemar
Original Message:
Sent: Feb 19, 2024 05:52 AM
We are changing some of our standards and part of this is a renaming of our vlan names for refreshed sites. is there a way to use role mapping or some other method. to Interrogate the switch and see if a vlan exists if not check the next vlan name until there is a match and assigned the matched vlan?
