ClearPass no TACACS REJECTs in syslog?
  • 1.  ClearPass no TACACS REJECTs in syslog?
    Posted Feb 02, 2024 06:30 AM
    I noticed that I'm not getting any REJECTs from a TACACS service in syslog.
    In the access tracker the REJECTs show up, but not on the syslog server. I did a packet capture to be sure the really aren't in the traffic and didn't see them there either. So it isn't a syslog server issue.
    The ACCEPTs show up fine on the syslog server side.
    These are syslog filter settings.
    Export Template: Session Logs
    Include Audit Entity Details:
    Export Event Format Type: Standard
    Local Facility Level: Local Use 1 (local1)
    Data Filter:
    [TACACS Requests]
    Columns Selection:
    Common.Username
    Common.Service
    TACACS.Remote-Address
    TACACS.Privilege-Level
    Common.Request-Timestamp
    Common.NAS-IP-Address
    Common.NAS-Name
    Common.Login-Status
    Common.Enforcement-Profiles
    Common.Roles
    Common.Alerts
    Common.Error-Code
    Anyone seen this before or have an idea what is going on?
  • 2.  RE: ClearPass no TACACS REJECTs in syslog?
    Posted Feb 13, 2024 08:28 AM
    I don't see TACACS rejects either in syslog (but do see accepts). Can you open a TAC Support case for that?
  • 3.  RE: ClearPass no TACACS REJECTs in syslog?
    Posted Apr 05, 2024 11:15 AM
    Thanks for checking Herman, created a support case and was able to solve the specific issue with their guidance. It has to do with the Columns Selection. Some of those fields don't exist in the TACACS reject so then the whole request won't be send via syslog.
    When you remove some of the selected fields like Common.Roles and TACACS.Privilege-Level the REJECTS are logged via syslog. But now the ACCEPTS don't show the Roles anymore which was useful. So I end up with two syslog filters causing part of the info to be logged twice.
    Not fully sure how to make this work as I want.
