Network Management
Clearpass not able to authenticate do1x clients with EAP timeouts
This thread has been viewed 34 times
  • 1.  Clearpass not able to authenticate do1x clients with EAP timeouts
    Posted Apr 15, 2024 02:35 AM
    Hi , We have been facing issues with one of our subscriber nodes of clearpass( in a cluster with publisher which is not experiencing this problem) , dot1x authentications are failing intermittently droping networks , errors shows EAP transactions timed out( both on wired and wireless) . I have ERT engineers from Aruba Clearpass and Switching team and no one is able to pinpoint the issue . This is happening on all Aruba OS , Aruba OS CX and Cisco Switches which are configured for this specific Clearpass Subscriber node , regardless of switch type .Sometimes it works and sometimes it does not .
    No certificates have been updated on clearpass ends( this setup has been functional for a long time until Jan 2024) , these clearpass certs have been there for some time and are not expired at all , checked default MTU size on Switch which is 1500 for all end switches .
    Functional Clearpass is in a different DC and non-functional CPPM is in a different DC . Any clues or cues..
    This is going on for months and affecting HQ as well
  • 2.  RE: Clearpass not able to authenticate do1x clients with EAP timeouts
    Posted Apr 15, 2024 02:44 AM
    Are you using EAP-TLS? In that case, a common issue is that when the client sends it's client certificate, the resulting RADIUS packet from switch/AP/controller to ClearPass becomes too big. One solution is Jumbo frames end-to-end (so 1500 MTU is not enough), another is configuring your switches/APs for EAP fragmentation (with like 1000 bytes or so), or you can change to RadSec which by using TCP instead of UDP avoids the MTU issue all together. Changing to EC certificates on your client (and intermediates) may help as well as it reduces the size of the client certificate + intermediates.
    ClearPass has an EAP-fragmentation by default (think with 1024 bytes), so from that side there should not be an issue. It's in general the path from switch to the RADIUS server causing these timeouts, and with EAP-TLS, TEAP or other authentication methods that use client certificates.
    Did you already find out if/where/what RADIUS packets are dropped?
  • 3.  RE: Clearpass not able to authenticate do1x clients with EAP timeouts
    Posted Apr 18, 2024 05:38 PM
    Thanks for responding .
    So far we did packet captures on Clearpass where packets are for EAP are arriving fragmented ( from working and non working scenario) , on switch end also ERT engineers said they ahve not yet seen jumbo packets leaving the switch . How and where can i enable Rad Sec , looking for documentation already
    No we have not yet figured out where are packets are being dropped . only checked at L2 switcha and clearpass
  • 4.  RE: Clearpass not able to authenticate do1x clients with EAP timeouts
    Posted Apr 18, 2024 05:40 PM
    Also there are 5-6 hops in middle so packet packture is a little bit tough thing to do right now , any other suggestion , but if packet captures is needed on each hop i can do that as well
  • 5.  RE: Clearpass not able to authenticate do1x clients with EAP timeouts
    Posted Apr 23, 2024 03:41 PM
    What typically happens if MTU is the issue, is that you see the packet leaving the switch, but not arriving on the ClearPass. If that is the case, you can check somewhere in the middle if you can see the packet there, if not go further towards the switch, if so go further to the ClearPass. Note that when ClearPass is running as a VM, like ESXi, you have MTU settings on the hypervisor/vswitch/vnic as well. Once you know where the packets are lost, the solution is to increase the MTU there, but best is to make the full path jumbo. For RadSec, you may have a look at these tutorials.
  • 6.  RE: Clearpass not able to authenticate do1x clients with EAP timeouts
    Posted Apr 24, 2024 12:42 AM
    I have no idea if this will help you.  Its specific to EAP-TLS and jumbo.  But it did solve my EAP client timeouts.  I did not have issues before enabling Jumbo at the local site.
    4We ran into an issue during testing with an EAP-TLS Camera authentication showing timeouts in CPPM.   "Client did not complete the eap transaction".
    4Issue was present when the management vlan interface on the CX switch had "ip mtu 9198" (jumbo frames) enabled. Clearpass was across the WAN and we do not have end to end Jumbo enabled.  Jumbo in our case is only for local APs, Switches and Controller.
    4Clearpass has a setting for eap-tls fragmentation and it is defaulted to 1024.
    Administration » Server Manager » Server Configuration » Service Parameters » RADIUS Server » RADIUS: EAP-TLS Fragment Size
    4The CX switch has a default setting of 3072 bytes when Jumbo is enabled..
    4Adding the below command to the CX Switch tells CPPM that for EAP-TLS fragmentation only to use an MTU value of 1024.  This MTU setting is only used between the CX switch and Clearpass.
    aaa authentication port-access dot1x authenticator eap-tls-fragment towards-server 1024
    The MTU value you use should match what is on the Clearpass server.
  • 7.  RE: Clearpass not able to authenticate do1x clients with EAP timeouts
    Posted 3 days ago
    My company had this same issue this year. 1 subscriber node and 1 publisher, one was getting overloaded with eap requests. What fixed it was we realized we were pushing the requests to the VIP of the cluster and not both the subscriber IP address and publisher IP address. Once we added both addresses the problem was resolved.
