Clearpass not able to communicate with Intune
This thread has been viewed 26 times
  • 1.  Clearpass not able to communicate with Intune
    Posted Jul 07, 2020 11:10 AM
    Hello everybody,
    I know it's quite a recurent topic here but I have issues linking my clearpass with Azure Intune.
    I tried with version 6.8.0, 6.8.6, 6.9.0 and everytime it's the same. I get an HTTP 500 error resulting in my service not getting a RADIUS ACCEPT.
    I've fallowed to the letter the Clearpass Intune integration guide v3 (https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=35943) modulo the Intune graphical changes but every time the same : invalid NAC endpoint, invalid token, not able to query Intune,... cf log attached.
    Does someone have an idea ?
    Attachment(s)
    txt
    log clearpass intune.txt   3 KB 1 version
  • 2.  RE: Clearpass not able to communicate with Intune
    MVP GURU
    Posted Jul 07, 2020 11:11 AM
    What does the event viewer look like on the ClearPass server when trying to make the connection?
  • 3.  RE: Clearpass not able to communicate with Intune
    Posted Jul 07, 2020 11:30 AM
    Hi Dustin,
    No alerts in Event Viewer. Only in Access Tracker is the request being refused :
  • 4.  RE: Clearpass not able to communicate with Intune
    Posted Jul 07, 2020 01:19 PM
    From the extension's logs, the error indicates that you are unable to get the token.
    [2020-07-07T14:37:50.812] [DEBUG] intune - Requesting token for resource "00000002-0000-0000-c000-000000000000".
    [2020-07-07T14:37:55.971] [ERROR] intune - Unable to get token. Error: getaddrinfo EAI_AGAIN login.microsoftonline.com:443
    at Object._errnoException (util.js:1024:11)
    at errnoException (dns.js:55:15)
    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:92:26)
    Please check if your DNS is able to resolve login.microsoftonline.com. Update the DNS and restart the extension.
  • 5.  RE: Clearpass not able to communicate with Intune
    Posted Jul 07, 2020 02:28 PM
    My DNS is working as I'm able to request update from Aruba servers (installed version is 6.8.0, updated to 6.8.6 then to 6.9.0).
    To not let a trail unfollowed, i checked :
    [appadmin@Clearpass2]# network nslookup login.microsoft.com
    Server: 10.3.20.5
    Address: 10.3.20.5#53
    Non-authoritative answer:
    login.microsoft.com canonical name = a.privatelink.msidentity.com.
    a.privatelink.msidentity.com canonical name = prda.aadg.msidentity.com.
    prda.aadg.msidentity.com canonical name = www.tm.a.prd.aadg.akadns.net.
    Server: 10.3.20.5
    Address: 20.190.137.75
    Address: 20.190.137.10
    Address: 20.190.137.98
    Address: 20.190.137.69
    Address: 40.126.9.77
    Address: 20.190.137.14
    Address: 20.190.137.73
    Strangely I had to nslookup 2 times to get the IP answer.
    Should I activate DNS caching to avoid DNS taking to long to answer the request ?
  • 6.  RE: Clearpass not able to communicate with Intune
    Posted Jul 08, 2020 04:07 AM
    New tests this morning, I completely reinstall the Extension after Cache DNS activation. No change in the behavior but more logs.
    The App has autorisation for graph and intune compliance, the device is enrolled...
    For thoses that want to check by themselves (it's a lab) :
    Tenant ID : 935534e0-ea0b-4135-bf1f-9206e6c90aec
    Client ID : 808818ac-7488-41a1-93e3-52ea70253994
    Client secret : gthV.nN-H2JQQ_8.KO_M11eocCAE7yU1Ly
    Been on this topic for nearly a week now, been twiking my clearpass on all direction and starting to loose focus...
    Attachment(s)
    txt
    cpass_log_error.txt   7 KB 1 version
  • 7.  RE: Clearpass not able to communicate with Intune
    Posted Jul 08, 2020 12:52 PM
    The current issue appears to be with DNS rather than Intune or the extension itself.
    You can work with Aruba TAC to debug the DNS issue.
  • 8.  RE: Clearpass not able to communicate with Intune
    Posted Jul 15, 2020 05:11 AM
    Hi all,
    Just to inform you. The issue is probably found.
    It seems the one that configured the DNS made a typo on its forwarders config. It was working sometimes but was not consistent and was the root cause of the application timed out.
    Thanks for everyone thoughts
