Clearpass Onboard and Google authentication setup
  • 1.  Clearpass Onboard and Google authentication setup
    Posted 5 days ago
    Hi All,
    I'm trying to setup a BYOD Wi-Fi using Clearpass and Google as the IDP.  I found this guide online to set it up.
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00091071en_us
    Is this the most current documentation or guide?  It was last updated 2018.  I followed this guide, but I can't get it working.  I used OAuth 2 and Google secure LDAP for authorization.  When I try to connect to this Wi-Fi with a MacBook, the Mac authentication windows pops up.  The Guest page should pop up instead and show a Google login page.
  • 2.  RE: Clearpass Onboard and Google authentication setup
    Posted 2 days ago
    I'm not aware of a newer version of that guide. If you don't see the redirect to the correct page, there probably is something wrong with your WiFi setup. It's less likely ClearPass related.
    Because it would help to see what you see, and from there find out what is happening instead of what should happen, and check that against the configuration to find a solution, it is probably best to open a TAC Case or work with your Aruba partner. There is just not enough information to provide other guidance.
  • 3.  RE: Clearpass Onboard and Google authentication setup
    Posted 2 days ago
    Ok thank.  I ended up opening a case.
