Can anyone please let me know whether SNMP On connect will work with a laptop and phone from a single swithc port like 802.1X.?
Faiz
I think for such a scenario, using MAC authentication is a better solution. If you follow the Wired Authentication Solution Guide, it should help you get started with that. In general, you should use OnConnect only in situations where you really can't use MAC authentication.
