Clearpass Onguard Auto-Remediation
  • 1.  Clearpass Onguard Auto-Remediation
    Posted Apr 28, 2014 07:58 AM
    Often people have questions on Clearpass Onguard like what firewalls and anti-virus softwares are supported? What P2P apps do we detect? etc. And which of these do we support auto-remediation for? For example, which firewalls can Onguard enable for the user automatically if the administrator has set a policy for it to be enabled. etc. This article will answer these questions.
    For a complete list of supported third-party products and auto-remediation actions, go to the following page in your Clearpass server: Administration > Agents and Software Updates > OnGuard Settings. Next, click the Help link on the top right, and then click the OnGuard Agent Support Charts link.
    Here are some screenshots:
    The meanings of fields/columns in Support Charts and which of them is auto-remediation action is listed below:
    Common Attributes
    Attribute NameDescription
    Product_NameProduct Name
    VersionProduct Version
    AntiVirus/AntiSpyware
    Attribute NameDescriptionAuto-Remediation Action
    GetDataFileTimeRetrieve the last modification time of the current definition/pattern file used by the Antivirus productNo
    GetDataFileVersionRetrieve the current version of the definition/pattern file used by the Antivirus productNo
    EngineVersionRetrieve the version of the Antivirus' scanning engineNo
    Check RTPRetrieve the state of the Real-Time Protection (RTP) of the Antivirus productNo
    LiveUpdateUpdate the Antivirus product (Dat File, Engine Version etc.)Yes
    Sync/Async UpdateNot Used
    SetRTPEnable/disable the Real-Time Protection (RTP) of the Antivirus productYes
    LastScanTimeRetrieve the date and time of the last completed full system scan ran on the endpoint by the Antivirus productNo
    FullSystemScanLaunch a full system scan for the Antivirus productYes
    GetVirusDefServFull System Scan In ProgressNo
    IsFullScanInProgCheck if the Antivirus product is currently running a full system scanNo
    DiskEncryption
    GetLocationsRetrieve list of encrypted locationsNo
    GetEncStateRetrieve encryption state of location (drive)No
    Firewall
    IsEnabledRetrieve Firewall State (enabled/disabled)No
    TurnOnEnable the FirewalYes
    TurnOffDisable the FirewallYes
    P2P
    IsRunningRetrieve running state of P2P applicationNo
    TerminateTerminate running P2P applicationYes
    Patch Management
    IsEnabledCheck if Patch agent is enabled or notNo
    EnableSet Patch Agent to enabled stateYes
    ListMissingDetect missing patchesNo
    InstallMissingInstall Missing PatchesYes
    Virtual Machine
    EnumerateVMsEnumerate Virtual Machines on the systemNo
    GetVMInformationGet extended information of a virtual machine (Name, Path, OS Version etc.)No
    PauseVMPause the running Virtual MachineYes
    StopVMStop the running Virtual MachineYes
    GetHypervisorTypeRetrieve Hypervisor Type of Virtual MachineNo
    Meaning of value fields:
    V - Implemented
    O - Not Supported
    X - Not Implemented
    Z - Implemented on Windows with Security Center (WMI) available
  • 2.  RE: Clearpass Onguard Auto-Remediation
    Posted Aug 16, 2018 09:17 AM
    This information is not current as of the 6.6+ releases.
    The support charts are now accessed by going to Administration >> Documentation.
