last person joined: 7 hours ago
Clearpass Onguard Bounce
  • 1.  Clearpass Onguard Bounce
    Posted Apr 04, 2022 04:59 AM
    I'm setting up Clearpass Onguard with posture checking and dynamic VLAN's.
    First a new PC is put in a guest VLAN, after the posture check, the agent bounces the user and he should connect to the same network again in the secure vlan.
    When the agent bounce the client, the client connects at a previously known network. But not the Clearpass one.
    Is there an option in Onguard to enforce a SSID?
    Kind regards,
    Thomas Willems
  • 2.  RE: Clearpass Onguard Bounce
    Posted Apr 04, 2022 08:28 AM
    There is no attribute to control which SSID an endpoint connects to. That is a client decision
    Evan Fisher
  • 3.  RE: Clearpass Onguard Bounce
    MVP
    Posted Apr 11, 2022 02:40 AM
    You should enforce it with GPO if your computer is part of a Domain Infrastructure. Else, you can use Clearpass OnBoarding feature.
    Shpat | MVP 2021 | ACEP | ACMP | ACCP | ACDP |
