ClearPass OnGuard deployment with Dell PowerConnect switches without CoA
  • 1.  ClearPass OnGuard deployment with Dell PowerConnect switches without CoA
    Posted Sep 20, 2017 06:35 AM
    Hi
    We deploy Aruba ClearPass OnGuard in environment when Dell PowerConnect 55xx series switches. As we checked those switches don't support CoA and we consider other method of client reauthentication. From some documents which I have gone through It is not clear for me what method will be the best. We consider:
    - snmp enforcment
    - CLi enforcement
    - short reath time
    - phisical reconnect
    - Agent based
    Has someone deployed Dell PowerConnect switches with OnGuard and could share experiance ? what would be the best solution ?
    Any documentation ?
    I will appreciate any help
    Best regards
    Karol
  • 2.  RE: ClearPass OnGuard deployment with Dell PowerConnect switches without CoA
    Posted Sep 20, 2017 06:37 AM
    If your network infrastructure does not support CoA/DM, you can leverage the Agent Bounce feature of the OnGuard Persistent Agent.
  • 3.  RE: ClearPass OnGuard deployment with Dell PowerConnect switches without CoA
    Posted Sep 20, 2017 06:55 AM
    ok, thanks for fast response
    I will try this solution
    best regards
    Karol
  • 4.  RE: ClearPass OnGuard deployment with Dell PowerConnect switches without CoA
