This post shows the parameters for the OnGuard Installer. Can you try those?
Original Message:
Sent: Nov 08, 2022 09:00 AM
Subject: Clearpass onguard exe package silent installation command lines
Hi All,
I am trying to install the clearpass onguard package with silent install commands.
Can anyone please help me with the "Clearpass onguard exe package silent installation command lines" as I have tried several methods like
"ClearPassOnGuardInstall.exe" , ClearPassOnGuardInstall.exe /s /v /qn, ClearPassOnGuardInstall.exe /s /qn, ClearPassOnGuardInstall.exe /silent /qn /norestart none of them working as expected but it is wo
Thanks in Advance.
Thanks and Regards
Naresh
