Clearpass - Onguard - setup
  • 1.  Clearpass - Onguard - setup
    Posted Feb 26, 2015 04:08 PM
    Hello ,
    I am new to Aruba. I was trying to setup clearpass for posture assessment of wired dot1x network connections. We use 3750 cisco switches and authentication is against AD servers.
    Is there is a setup guide available i can find?
    Im trying to accomplish the following
    1. User connects the computer
    2. onguard does the posture assessment, if passes
    3. Clear pass looks for his/her department and assigns the vlan
    4. If fails,shows the remediation or do auto remediation.
    I got the vlan assignment part working as that seems self explanatory.
    I understand that we have multiple options for doing the posture assessment
    1. webpage
    2. install application
    We would like to look at both
    If someone can point me to a configuration guide or suggest me ideas i will be greatful.
    Thanks!
  • 2.  RE: Clearpass - Onguard - setup
    Posted Feb 26, 2015 04:14 PM
    Are you working with an Aruba partner? It can be a bit complex to explain on here.
    Tim
  • 3.  RE: Clearpass - Onguard - setup
    Posted Feb 26, 2015 04:21 PM
    This is what i have done so far.
    we are using 802.1x to AD authentication on cisco 3750 switches.
    On Clearpass
    Configuration -> service (new service) - 802.1x wired
    defaults in the service
    authentication to AD server
    we are not doing any roles
    Enforcement - new policy - I have created 2 conditions.
    1. tips: rols equals {user authentication}
     and tips:posture equals healthy(0)
    Then assign employee vlan
    2. Tips:role Equals
     and tips:posture NOT_Equals healthy(0)
    Then cisco-wired onguard redirect and temporary vlan
    For the cisco-wired onguard redirect profile i have set a url redirect to clearpass onguard
    ---Testing---
    Connected a windows 7 machine to the port - it does the authentication and fails rightaway.
    however on the access tracker clearpass, i can see that login-status is ACCEPT
    and summary says its using the right service that i have created and it falls under condition-2
    on the output its sending the vlan attributes for temporary vlan and cisco-avpair url redirect.
    As its not authenticating i cant get to the url. However in the profiles when i remove the radius attribute for url redirect and keep just the vlan  machine authenticates with my credentials and gives me the vlan i need but with out posture assessment.
    One thing i have noticed is in access tracket - summary - I see below
    System Posture Status:
    UNKNOWN (100)
    I must be missing something. Any help will be much appreciated.
  • 4.  RE: Clearpass - Onguard - setup
    Posted Mar 02, 2015 01:19 PM
    Is it machine authenticating of user?
    What does the alerts tab say?
  • 5.  RE: Clearpass - Onguard - setup
    Posted Mar 02, 2015 01:22 PM
    Yes, authentication using user credentials.
    In the access tracker i only see summary , input and output .. I dont see alerts tab
