Clearpass OnGuard with Meraki Wireless - Dropped Connections
  • 1.  Clearpass OnGuard with Meraki Wireless - Dropped Connections
    Posted Feb 14, 2024 01:57 PM
    We are working on an implementation that consists of Clearpass (with OnGuard) and Meraki wireless. We are having issues with clients roaming between Meraki AP's and re-authenticating.  When clients are roaming between AP's, they are re-authenticating against Clearpass.  The issue we are experiencing is if the OnGuard posture status cache has expired (which happens after 5 minutes) then the client will connect and the posture be seen as "unknown" which then places the client on the Quarantine VLAN until a new "Healthy" assessment is reported by the Agent.  When that happens, Clearpass will send down a Meraki-Terminate-Session which then pushes another re-authentication and places the client in the correct VLAN.  We have a TAC case open but the TAC engineer said this is expected.  Our customer is not accepting this as all wireless connections should be seamless when roaming (which I agree).  Is there a better way to accomplish seamless roaming when utilizing OnGuard with Meraki wireless?  Thank you!
  • 2.  RE: Clearpass OnGuard with Meraki Wireless - Dropped Connections
    Posted Feb 14, 2024 04:53 PM
    What kind of roaming settings do you have enabled on the Meraki WLAN?
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: Clearpass OnGuard with Meraki Wireless - Dropped Connections
    Posted Feb 19, 2024 08:33 AM
    We have 802.11r enabled but since we have CoA enabled we cannot enable 802.11k or v.  Thank you.
  • 4.  RE: Clearpass OnGuard with Meraki Wireless - Dropped Connections
    Posted Feb 15, 2024 03:57 AM
    You can change the Posture Cache timeout under Service Configuration, Service Parameters, ClearPass Network Services, to value that does work:
    Or play with the OnGuard keepalive and Check Interval settings (under Global Agent Settings).
    I agree that on a roam the client should not go through a full reauthentication, which may be a misconfiguration in the WLAN settings.
  • 5.  RE: Clearpass OnGuard with Meraki Wireless - Dropped Connections
    Posted Feb 19, 2024 08:44 AM
    Thanks Herman.  We will adjust the cache timeout and see if that improves the roaming re-auth.  Unfortunately there are not many bells and whistles to adjust with Meraki.  We have 802.11r enabled but cannot enable 802.11 k and v since we have CoA enabled on that .1x SSID.
