You can change the Posture Cache timeout under Service Configuration, Service Parameters, ClearPass Network Services, to value that does work:
Or play with the OnGuard keepalive and Check Interval settings (under Global Agent Settings).
I agree that on a roam the client should not go through a full reauthentication, which may be a misconfiguration in the WLAN settings.
Original Message:
Sent: Feb 14, 2024 01:57 PM
Subject: Clearpass OnGuard with Meraki Wireless - Dropped Connections
We are working on an implementation that consists of Clearpass (with OnGuard) and Meraki wireless. We are having issues with clients roaming between Meraki AP's and re-authenticating. When clients are roaming between AP's, they are re-authenticating against Clearpass. The issue we are experiencing is if the OnGuard posture status cache has expired (which happens after 5 minutes) then the client will connect and the posture be seen as "unknown" which then places the client on the Quarantine VLAN until a new "Healthy" assessment is reported by the Agent. When that happens, Clearpass will send down a Meraki-Terminate-Session which then pushes another re-authentication and places the client in the correct VLAN. We have a TAC case open but the TAC engineer said this is expected. Our customer is not accepting this as all wireless connections should be seamless when roaming (which I agree). Is there a better way to accomplish seamless roaming when utilizing OnGuard with Meraki wireless? Thank you!
