Clearpass: Online Status Data Filter Not Working
  • 1.  Clearpass: Online Status Data Filter Not Working
    Posted Nov 25, 2014 11:02 AM
    I am running CPM 6.4.1.6.
    I want to create a filter under Analysis and Trending that shows the Online Status Data of online or offline.
    This is the field I am referring to under Request Details for Access Tracker
    This is a simple Data Filter I made to test that does an OR on the two fields I beleive refer to "Online Status".
    The issue is I am not returning any results.
    Thanks for any feedback.
  • 2.  RE: Clearpass: Online Status Data Filter Not Working
    Posted Nov 25, 2014 11:28 AM
    The "online" status is tied to radius accounting.  Do you have your NAS sending radius accounting information in your environment to ClearPass?
  • 3.  RE: Clearpass: Online Status Data Filter Not Working
    Posted Dec 01, 2014 09:30 AM
    Thanks Joe. Yes, I can see differentiation between offline/online/disabled in access tracker.
    I checked out the radius accounting as you suggested and thought I found it, but still not working.
    When I inspect the element it looks like using "contains" offline/online should work.
    The field I am looking in under Radius Accounting is "Acct-Status-Type"
  • 4.  RE: Clearpass: Online Status Data Filter Not Working
    Posted Dec 01, 2014 11:14 AM
    Do you have this enabled ?
  • 5.  RE: Clearpass: Online Status Data Filter Not Working
    Posted Dec 01, 2014 11:18 AM
    Yes, i do.
    Am I searching the correct field now?
    "RADIUS Acct-Status-Type"
  • 6.  RE: Clearpass: Online Status Data Filter Not Working
    Posted Dec 01, 2014 11:20 AM
    That is not the built-in Status you are seeing. That is a RADIUS attribute. I'm not sure you can currently do what you are trying.
  • 7.  RE: Clearpass: Online Status Data Filter Not Working
    Posted Dec 01, 2014 11:23 AM
    I find it odd that it's an informational field and I can't filter by it?
  • 8.  RE: Clearpass: Online Status Data Filter Not Working
    Posted Dec 01, 2014 11:24 AM
    It's not the field you are looking for. The online status is a ClearPass calculated field. The one you are seeing is an IETF RADIUS attribute.
  • 9.  RE: Clearpass: Online Status Data Filter Not Working
    Posted Dec 01, 2014 11:26 AM
    Understood thanks, if i can not filter by the calculated field is there another attribute that I can filter by that would accomplish my end goal?
  • 10.  RE: Clearpass: Online Status Data Filter Not Working
    Posted Dec 02, 2014 11:46 AM
    Endpoint Online status is computed from InsightDb and the query is as follows:
    SELECT end_time IS null AS online FROM radius_acct WHERE calling_station_id='%{Connection:Client-Mac-Address-NoDelim}' ORDER BY updated_at DESC LIMIT 1;";
  • 11.  RE: Clearpass: Online Status Data Filter Not Working
    Posted Dec 02, 2014 02:43 PM
    Kudos!
    I entered that in the custom SQL though and im getting this error:
     Invalid SQL syntax - ERROR: syntax error at or near "SELECT" Position: 541
    EDIT: Okay i see what you mean, that wasn't a custom query that can be ran in the datafilter custom SQL but it may help extract the info.
