Cloud Managed Networks
ClearPass operator login with EntraID
  • 1.  ClearPass operator login with EntraID
    Posted May 14, 2024 07:22 AM
    Is it possible to authenticate operators to the Policy Manager UI using EntraID?
    Documentation only states that LDAP is possible.
    Operator Profiles
    I see a lot of customers moving to only Entra ID only as there is almost no use case anymore for traditional LDAP.
    Cheers! Fabian Klaring.
  • 2.  RE: ClearPass operator login with EntraID
    Posted May 15, 2024 05:12 AM
    You can achieve this through Policy Manager > Configuration > Identity > Single Sign-On (SSO).
    Entra ID integration with SAML then check the applicable ClearPass elements you wish to authenticate with Entra ID.
    https://www.arubanetworks.com/techdocs/ClearPass/6.11/PolicyManager/Content/CPPM_UserGuide/identity/ConfiguringSingleSignOn.html
