Clearpass overriding of client certificate ocsp URL
  • 1.  Clearpass overriding of client certificate ocsp URL
    MVP EXPERT
    Posted Nov 30, 2021 11:50 AM
    Another quick question.
    We currently are using  eap-tls with CRL lists and the client certs do not have an ocsp url embedded in them
    If I set cppm up to use  eap-tls with ocsp and  configure it to  "override the certifiate ocsp url", will the cert validation work ( even if the clent cert doesnt have the ocsp url , assuming what cppm is talking to knows about the client cert?
    A
    Alex Sharaz
  • 2.  RE: Clearpass overriding of client certificate ocsp URL
    Posted Dec 01, 2021 08:35 AM
    I believe that the override works even if there is no OCSP data in the certificate. But it's simple to test if you have certificates without OCSP info.
