I have not worked with such an environment, so can't really help. If you don't get an answer here, please work with Aruba Support to get a response.
Original Message:
Sent: Dec 04, 2023 07:53 AM
Subject: ClearPass & Palo Alto Global Protect VPN (GPVPN) Posture validation.
Hi guys,
My client has Panorama that manages 5 firewalls, but in the ClearPass extension I can only place 1 panHost. Is there any way to take advantage of the ClearPass integration with Palo Alto GPVPN with posture validation in an environment where the client has several firewalls used for client VPN managed by Panorama?
Another point is that I followed the same documentation mentioned previously but I don't see the Dynamic Address Group (DAG) being fed.
I collected logs in ClearPass and see the error below:
172.17.0.2 is extension IP and 172.18.x.x client IP.
I thank the help of all.
Thanks.
