ClearPass Policy Manager 6.4 Quick Start Guide
  • 1.  ClearPass Policy Manager 6.4 Quick Start Guide
    Posted Feb 09, 2015 10:43 AM
    Tech Note for installing CPPM 6.4 states:
    10.When you see the banner on the virtual machine console, you can log in by following the instructions in the ClearPass Policy Manager Quick Start Guide.
    I'm unable to locate a ClearPass Policy Manager 6.4 Quick Start Guide - anyone know where this can be found?
  • 2.  RE: ClearPass Policy Manager 6.4 Quick Start Guide
  • 3.  RE: ClearPass Policy Manager 6.4 Quick Start Guide
    Posted Feb 09, 2015 10:47 AM
    Thanks, Tim. I had taken a look at this doc but couldn't seem to find what they were referring to in there. I'll peruse it a little closer.
  • 4.  RE: ClearPass Policy Manager 6.4 Quick Start Guide
    Posted Feb 09, 2015 10:48 AM
    Check Chapter 2:  Accessing Policy Manager.
  • 5.  RE: ClearPass Policy Manager 6.4 Quick Start Guide
    Posted Feb 09, 2015 10:50 AM
    The Quick Start Guide has been rebranded the Gettting Started Guide.  They should contain the same  (updated) information.
  • 6.  RE: ClearPass Policy Manager 6.4 Quick Start Guide
    Posted Feb 09, 2015 10:45 AM
    I don't see one for 6.4 specifically, but the 6.2 Quick Start Guide can be found here.   Also, the 6.4 Getting Started Guide should have the information you need.
    http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=11740
    The Getting Started Guide:
    http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=14791
  • 7.  RE: ClearPass Policy Manager 6.4 Quick Start Guide
    Thank you - I took a look at this one but it seemed to be specific to the hardware applicance rather than to VM installation. Safe to say there's no significant difference?
  • 8.  RE: ClearPass Policy Manager 6.4 Quick Start Guide
    Posted Feb 09, 2015 10:52 AM
    Correct. The CLI and UI are identical.
  • 9.  RE: ClearPass Policy Manager 6.4 Quick Start Guide
    Posted Feb 09, 2015 10:55 AM
    Thank you.
  • 10.  RE: ClearPass Policy Manager 6.4 Quick Start Guide
    Posted Feb 09, 2015 10:53 AM
    The first chapter is more specific to the appliance; Chapter 2 on is more generic.
  • 11.  RE: ClearPass Policy Manager 6.4 Quick Start Guide
    OK, thanks.
