ClearPass Policy Manager in VM and issue on network connectivity.
  • 1.  ClearPass Policy Manager in VM and issue on network connectivity.
    Posted Aug 22, 2012 03:58 AM
    Hi, recently i am setting up the ClearPass Policy Manager for my office and I do facing some issue on the VM setting especially for the network connectivity. Below is the scenario
    I am using below hardware and software for the exercise
    - 1 unit server with loaded WinServer 2008 and VM WorkStation 8.0.2.The server come with 2 NIC.
    - I have downloaded ClearPass Manager 5.2.0 ( 64-bits ) in VM version
    Below is my IP address assignment for the hardware and VM,
    - Server NIC IP for the 2 network card ( NIC 1 – 10.10.10.7 subnet 255.255.255.0 Gateway 10.10.10.1 ) ( NIC 2 – 192.168.2.7 subnet 255.255.255.0 Gateway 192.168.2.1 )
    - ClearPass Policy Manager in VM (Hostname – SCH.com) ( Management IP – 10.10.10.8 subnet 255.255.255.0 Gateway 10.10.10.1 ) ( Data Port IP - 192.168.2.8 subnet 255.255.255.0 Gateway 192.168.2.1 )
    ***In the VM network setting I have configure to the bridge mode for the 2 network adapter. ( VM –Setting-Network Adapter-Bridged )
    Issue that facing,
    - Currently I am not able to ping the ClearPass Policy Manager VM interface inside the server2008 ( 10.10.10.8 and 192.168.2.8 )
    - I am not able to bring up the GUI interface even I have key in https://SCH.com/tips ***The main reason is because I can’t ping the VM interface
    Additional info,
    I have try to customize the network profile in VM and tie it to the dedicated VMnet interface and it still can’t work.
  • 2.  RE: ClearPass Policy Manager in VM and issue on network connectivity.
    Posted Aug 22, 2012 07:54 AM
    Not sure if this is part of the problem, but I had thought that Policy Manager was only supported on ESX/ESXi servers; and not Workstation.  ClearPass Guest has a Workstation/VMware Player download.
  • 3.  RE: ClearPass Policy Manager in VM and issue on network connectivity.
    Posted Aug 23, 2012 02:04 AM
    Yup, i have install on ESX/ESXi and it working fine, \
    it seem the VMwork station can run the ClearPass image but it does not mean support on the platform.
  • 4.  RE: ClearPass Policy Manager in VM and issue on network connectivity.
    Posted Aug 23, 2012 11:10 AM
    Here is one way of making it work under VMware Workstation:
    In the .vmx simply replace the network drivers loaded (probably vlance) by
    ethernet0.virtualDev = "e1000"
    ethernet1.virtualDev = "e1000"
    for explanation see http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1001805
    JF
  • 5.  RE: ClearPass Policy Manager in VM and issue on network connectivity.
    Posted Nov 29, 2013 03:15 AM
    Hi guy, for your information, i have install Clearpass 6.2 on WMWare Workstation 10 and it's works good ! i advice to you only for your model.
    yann
