ClearPass Policy Manager Web UI not accessible on network
  • 1.  ClearPass Policy Manager Web UI not accessible on network
    Posted Mar 23, 2018 04:56 AM
    I have installed CPPM6.6 ova on esxi6.5 for my lab. The installation is successful and I am able to the appadmin account from the esxi console.The CPPM has I.P 10.26.60.13/27 while the ESXi host has I.P 10.26.60.10/27. When I am trying to access the ESXi host from my LAN segment i.e 10.20.208.197/22 the host is accessible fine, but the CPPM isn't accessible fromthis segment. Neither the web UI is accessible nor the SSH or ping.
    I used the ESXi console of CPPM to ping my laptop's I.P but it cannot go through and shows the error- Network is unreachable.(ScreenShot attached)
  • 2.  RE: ClearPass Policy Manager Web UI not accessible on network
    Posted Mar 23, 2018 05:37 AM
    Can you post the IP configuration of the CPPM host?
    cppm: show ipcppm: show ip
  • 3.  RE: ClearPass Policy Manager Web UI not accessible on network
    Posted Mar 23, 2018 06:04 AM
    Hi, Please find the required details in the attached screenshots.
    P.S- I just came across the fact that WebUI shows the data port gateway is configured(10.26.60.1) while chile shows it is not configured.
  • 4.  RE: ClearPass Policy Manager Web UI not accessible on network
    Posted Mar 23, 2018 06:14 AM
    The MGMT interface is Mandator for ClearPass. I see no gateway is assigned to the MGMT interface.
    If you prefer to use one interface, then you should configure MGMT interface with the IP 10.26.60.13/27, otherwise configure the MGMT with a valid IP and gateway and then check the status of DATA interface config.
    Please update the ip address from the console or SSH.
    #configure ip <mgmt|data> <ipaddress> netmask <netmask address> gateway <gateway address>
  • 5.  RE: ClearPass Policy Manager Web UI not accessible on network
    Posted Mar 23, 2018 06:25 AM
    What is the purpose of two different ports? I thought that management port would come in handy for a physical appliance to directly access it thorugh management port in case of a network outage.
  • 6.  RE: ClearPass Policy Manager Web UI not accessible on network
    Posted Mar 23, 2018 06:30 AM
    No, it’s not an out of band management port. It is the primary interface.
  • 7.  RE: ClearPass Policy Manager Web UI not accessible on network
    Posted Mar 23, 2018 06:45 AM
    Then what is the purpose of data port?
  • 8.  RE: ClearPass Policy Manager Web UI not accessible on network
    Posted Mar 23, 2018 07:12 AM
    DATA port is optional.
    Ex: You can use the DATA port  (in DMZ) when you do not want to expose the MGMT port.
