Clearpass Policy Manager with external MS SQL DB for Guests
  • 1.  Clearpass Policy Manager with external MS SQL DB for Guests
    Posted Nov 20, 2013 12:35 PM
    I’m new the Aruba world have a problem with the authentication methods fort the guest users.
    We setup a new cp server with iap controller in our environment.  I configured the ipa with the cp for the guests at first with the local cp database, everything works J
    But I want to import my guest’s ids from the access system database where everybody had to check in. so I configured the external sql db source. In this database I have a table with the guest id and code from the chip card. I want to use these two fields for my guest login.
    The problem is when use pap (clear) as methods for authentication I get this error:
    PAP: CLEAR TEXT password check failed
    When I change pap to md5 and convert the password field in the sql table I get this:
    Cannot select appropriate authentication method
    Whats wrong in my configuration?
    thanks
    daniel
  • 2.  RE: Clearpass Policy Manager with external MS SQL DB for Guests
    Posted Nov 20, 2013 01:06 PM
    Can you paste the SQL query he is using to retrieve the password from the DB and also  may i know if  password is stored in cleartext in the DB ?
    thank you.
  • 3.  RE: Clearpass Policy Manager with external MS SQL DB for Guests
    Posted Nov 21, 2013 04:44 AM
    hi,
    this is the query i use.
    select Password from dbo.GuestUser where User = '%{Authentication:Username}'
    in the password field the md5 hash is stored.
  • 4.  RE: Clearpass Policy Manager with external MS SQL DB for Guests
    Posted Dec 04, 2014 07:06 AM
    hi,
    am trying to do same urs configuration,
    i want ti integrate clearpass with external sql server,
    could you please show me how did u configure sql query and the alias name on your clearpass??
    thank you
  • 5.  RE: Clearpass Policy Manager with external MS SQL DB for Guests
    Posted Apr 24, 2015 02:32 PM
    @sriram.subramanian do you have an answer for this question?
  • 6.  RE: Clearpass Policy Manager with external MS SQL DB for Guests
    Posted Sep 17, 2016 01:00 AM
    hi sir
    i have also same issue when integration with the MS SQL DB, can you show me how you do it, i also encounter same error as you mention in your 1st post.
    any one can help.
  • 7.  RE: Clearpass Policy Manager with external MS SQL DB for Guests
    Posted Sep 19, 2016 12:23 AM
    can you share configuration sir? i have also same case but failed,
