Clearpass Ports required in multi controller enviroment
  • 1.  Clearpass Ports required in multi controller enviroment
    Posted Sep 27, 2016 03:36 PM
    Hello
    If i got a  multicontroller enviroment
    I got 2 Controllers Master and stand by
    5 more local controllers
    I got a vlan that just exist inthe controller
    I configured the Captive portal profile on the master controller i redirect it to the CLEARPASS
    Do i need to open the ports just between the Clearpass and Master/Stand by controller?
    I dont need to open ports between local controllers and clearpass even if the aps that the clients are connected are on the APS terminated on the local controller?
    I belaive i have to open this
    Between Master and Stand by controller
    RFC 3576 - UDP port 3799
    RADIUS - UDP port 1812
    RADIUS Accounting Server - UDP port 1813
    HTTP : TCP port 80
    HTTPS: TCP port 443
    Question here(this ports should be bidirectionals???
    Also the Clients in vlan 999 that just exist in the controller should have access to clearpass trhoguh the port 80 and 443 so they have access to the clearpass portal.
    cheers
    Carlos
  • 2.  RE: Clearpass Ports required in multi controller enviroment
    Posted Sep 28, 2016 11:07 AM
    anyone?
  • 3.  RE: Clearpass Ports required in multi controller enviroment
    Posted Sep 28, 2016 11:43 AM
    Any controllers that could have APs on them need to have ports opened between them and clearpass..
  • 4.  RE: Clearpass Ports required in multi controller enviroment
    Posted Sep 28, 2016 12:32 PM
    thank you Collin
    The ports needs to be open bidirectionally???
    Cheers
    Carlos
