Clearpass problems with guest login after https certificate change
  • 1.  Clearpass problems with guest login after https certificate change
    Posted Feb 22, 2017 04:19 AM
    Hi@all,
    we have an other strange problem with our clearpass, we uploaded a https certificate to our clearpass, wie changed the ip to the hostname guest.domain.de in the IAP captive portal profile. Now we changed in the cp guest capitve portal the securelogin.arubanetworks.com to guest.domain.de.
    Now when we login to the captive portal with username and password, the captive portal redirects us to the clearpass admin login page and we havent entries in the access tracker with the guests username.
    mac auth works fine, and we have entries in the access tracker but new guests with username and password cannot login.
    have anyone an idea for this strange behavior?
  • 2.  RE: Clearpass problems with guest login after https certificate change
    Posted Feb 22, 2017 04:52 AM
    Change that back.
  • 3.  RE: Clearpass problems with guest login after https certificate change
    Posted Feb 22, 2017 04:57 AM
    yes, we tried it but the web browser says site not found... Can this be a problem with the instant https certificate?
  • 4.  RE: Clearpass problems with guest login after https certificate change
    Posted Feb 22, 2017 04:58 AM
    How can I resore the original Instant https certificate?
  • 5.  RE: Clearpass problems with guest login after https certificate change
    Posted Feb 22, 2017 05:01 AM
    What's the name on your Instant HTTPS certificate?
  • 6.  RE: Clearpass problems with guest login after https certificate change
    Posted Feb 22, 2017 05:02 AM
    instant.domain.local
  • 7.  RE: Clearpass problems with guest login after https certificate change
    Posted Feb 22, 2017 05:07 AM
    Change the highlighted on your guest page to instant.domain.local
  • 8.  RE: Clearpass problems with guest login after https certificate change
    Posted Feb 22, 2017 05:09 AM
    can I use the VC IP-Adress instead?
  • 9.  RE: Clearpass problems with guest login after https certificate change
    Posted Feb 22, 2017 05:15 AM
    No, as you're using HTTPS.
    It needs to be the subject name on your Instants HTTPS certificate which you have said is instant.domain.local.
  • 10.  RE: Clearpass problems with guest login after https certificate change
    Posted Feb 22, 2017 07:17 AM
    Make sure you're using a publicly signed certificate.
  • 11.  RE: Clearpass problems with guest login after https certificate change
    Posted Feb 22, 2017 07:26 AM
    is the securelogin.arubanetworks.com public signed? I restored it to the factory default certs
  • 12.  RE: Clearpass problems with guest login after https certificate change
