Clearpass profiler doesnt seems to be working...
This thread has been viewed 22 times
  • 1.  Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 06:29 PM
    Okay i set the DHCP server on my L3 switch
    Which has the DHCP server and also it has the Clearpass policy manager as another entry just like the tech note said to do it.
    http://d1x3hnhct7p62q.cloudfront.net/SupportSite/ProductionFiles/5b2e82c2-de73-4151-be12-2cbed524db8e/ClearPassProfileTechNote.pdf?Expires=1396131894&Signature=V6WsM~F4X8UkKIce4x13aJpRGwBDlgC8CmRsPyMNJUsq0jVV~iU8GSAtdTl0JKePDBkIn72Eh2Y7ZCGlLCkVCedCwWS9cYyfsKHaEe5w2GpvJe8ebPvxeGQuTYpX3UObkYzCVQcIOkzVfPBH4mFTRbX2sL4D~Yt2ThT1yuYoYzYVGowFlKSIdEshdWv~uYI6M5OOcleuFb4--rlmbKzuiSRqZaS--FQstktvd5EVvdYI5MErJ2XMHajPYANOvK4T2NuRbioEd4kMc4EbSgcBmFlAgdr3WIaejjHNbwdlB1u~jrNbRMBG-bZ0nEmQkgoudRMKULoGBhfaHoLi~3T9qg__&Key-Pair-Id=APKAJCOCR7KIA7QV5SEQ
    The Enable this server for endpoint classification is on
    The only thing i cannot find to do its the adding the license of the profiler as its not listed.. as this tech note is for clearpass 5 guess  maybe it does not apply this part to clearpass 6.3...
    I dont see any entry being updated  the clearpass just saw it long time ago when i was testing the clearpass guest feature... but now i want it to work with the DHCP doesnt seems to work... he has not see any new entry neither update their entires...
    Im here trying with my laptop doing ipconfig /release
    ipconfig /renew to force make it ask for the Ip address and doesnt seems to work...
    Any hint or advice on this??
    Cheers
    Carlos
  • 2.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 06:31 PM
    Profiler is included in 6.x, no extra license.
    I've never done DHCP on a switch before, but are you sure it is forwarding the requests to ClearPass? If the DHCP server is in the same segment, it might not relay?
    Can you span the uplink and run a packet capture?
    Also, ClearPass only profiles on a DHCP discover. So if you already have an address, release/renew will not work.
  • 3.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 06:39 PM
    Hello Tim!
    Ill delete the ip of the DHCP server... and ill try again.
    Well i did what the tech note says
    It tells you how to do it on a cisco layer 3 switch
    What i did was doing it on an alcatel switch instead but its the same...
    i did this
    interface
    <VLAN
    _NAME
    ip ad
    dress
    <IP_ADDR> <NETMASK>
    ip helper
    address
    <DHCP SERVER IP>
    ip helper
    address
    <CPPM IP>
    end
     On the alcatel switch...
    The ip helper which is the dhcp server address was already on the switch as we need it to send dhcp address to the machines on different vlans... so the only thing i did was adding another dhcp server which is the clearpass.
    And yes the DHCP server is on the same segment as the clearpass
    Why it wont  forward it?
    I though that the request reached the swtich core and the switch core just send the request to both ip helper address i had...
    Cheers
    Carlos
  • 4.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 06:40 PM
    OK, but is the DHCP server upstream or running on the switch itself?
    Can you try a fresh device that doesn't have a lease?
  • 5.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 06:42 PM
    it is a windows 2012 DHCP server...
    Cheers
    Carlos
  • 6.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 06:47 PM
    i went to the DHCP server
    Deleted the entry of my smartphone
    reconnect again and it took another ip addresss
    The profiler didnt updated it...
    Last time updated was on march 19 when i was using clearpass guest  :(
  • 7.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 06:56 PM
    my swtich seems to be sending the DHCP request
    ALT-CORE-> show ip helper stats
     Global Statistics :
        Reception From Client :
          Total Count =      63706, Delta =          0,
        Forw Delay Violation :
          Total Count =          0, Delta =          0,
        Max Hops Violation :
        Agent Info Violation :
        Invalid Gateway IP :
        Invalid Agent Info From Server :
     Server Specific Statistics :
        Server  172.16.3.30
            Tx Server :
              Total Count =      62320, Delta =          0
        Server  172.16.3.223
            Tx Server :
              Total Count =        137, Delta =          0
     Global Statistics :
          Total Count =      63708, Delta =          2,
        Server  172.16.3.30
            Tx Server :
              Total Count =      62322, Delta =          2
        Server  172.16.3.223
            Tx Server :
              Total Count =        139, Delta =          2
    ALT-CORE->
     As you see the counters are increasing on both Servers... the .30 which is the DHCP server and the .223 which is the clearpass server.
    There is no firewall or anything blocking bettween them.
    Cheers
    Carlos
  • 8.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 10:04 PM
    On the clearpass logs with the capture packet the dhcp packets are reaching the clearpass so its not that they are not reaching them...
  • 9.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 10:24 PM
    I feel bad for asking, but I still have to. You do have profiler enabled. :)
    Also you can enable span port and see if we are getting the packets.
    Just as a precaution go in the CLI and run.....   service restart all
    One other option to see if profiller is working is to do a snmp read of the switch and see if we pull arp data out of it.
  • 10.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 10:33 PM
    Hello Troy
    On my first message i said that i had the profiler on :)  its on by default... or at least i didnt turn it on it was already on.
    I dont have the dhcp span port enable, as on the technote it didnt say anything of that...
    Ill enable it and restart all the services..
    The profiler is working as i see that i got a captive portal on the clearpass for our guest visitors in our company :) and i can see that the last time for example my windows phone was updated
    look
    But i wansted it to work with the DHCP option... as the one is easier to configure.
    I bealive it should work but something silly its happening or somethign silly im doing that is not working :(
    Cheers
    Carlos
  • 11.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 10:35 PM
    Troy which method do you use  when we are not using onboarding which it will get the information form it or when you are not using on guard and you are not getting the information from the agent?
    I though that DHCP could be the best way to go but now i encounter this :P
    Cheers
    Carlos
  • 12.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 10:44 PM
    i also did some packet capture which show you
    As you see the packet of the dhcp is reaching the clearpass... and the ip address requested is reaching the clearpass
  • 13.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 10:48 PM
    well i turned the dhcp span port i restarted all the services and i still that entry is not updated on the clearpass... :(
  • 14.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 11:10 PM
    Troy i did more test
    I took a new computer that never used and i see the entry on the clearpass which was with the dhcp which is good
    I took another Windows laptop but this time  this computer was registered by the profiler a while ago with the:
    Host User Agent:	Mozilla/5.0 (Windows NT 6.1; WOW64; rv:28.0) Gecko/20100101 Firefox/28.0
     It had that entry when i was using the clearpass guest so tahts why it was suing the host user agent. and clasified as "windows" alone
    Now i turn it again and im not using clearpass guest... i just connected to the bussiness network, it says it updated it just now... but it keep clasiffiing it as "windows" when its should classified it as "windows 7" just like my other laptop i turned on.
    I see this entry
    Shouldnt it update it as windows 7 ? yeah it says it was updated just now but it just tellin gme that is a windows machine not a windows 7 manchine
    Should be like this?
    As an aside note my windows phone still have not yet updated on the profiler  his last update was still a while ago even if im connecting right now...
    So well im confused if it working or not
    Seems to be partially working for me...
    Cheers
    Carlos
  • 15.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 11:14 PM
    Well i jsut saw and it seems that took a bit but after restarting the services now i see that the windows phone finally reported!!
    Thanks troy :)
    Sorry for flooding your email with all my messages...
    But well it seems to work now but just wondering why my windows laptop wont update to windows 7 and it stay on windows alone?
    And it also keep telling me that the method that it used was host user agent as well with my windows phone it says the same.
    Cheers
    Carlos
  • 16.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 11:24 PM
    Carlos,
    You should configure IF-MAP on the controller pointing to ClearPass to get all of the information by looking at this:  http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Management_Utilities/CPPM-ifmap.htm
    Sometimes DHCP fingerprinting only gets you so much information.  The browser agent information is not transferred in the fingerprint.  It looks like it could only tell that it is a Windows computer from the fingerprint.  If you configured if-map, the browser agent information would be transferred to CPPM without the fingerprint.  Configure IF-MAP, delete the endpoint and see if works.
    If you open a browser and hit the clearpass guest page, ClearPass can add the browser agent information without ClearPass.  If you open a browser, but do not hit the ClearPass guest page, Clearpass will not have the browser agent information without IF-MAP being configured...
  • 17.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 29, 2014 11:59 PM
    Hello Collin
    Does this feature is just available on 6.4 ?
    because im on 6.3 lastest patch and doesnt seems to work :(
    (Office_Alternetworks) (config) #ifmap
    % Invalid input detected at '^' marker.
    Cheers
    Carlos
  • 18.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 30, 2014 12:05 AM
    It should be in ArubaOS 6.3:  http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Management_Utilities/CPPM-ifmap.htm  It should work....
    See if you can find it in the GUI under "all profiles":
  • 19.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 30, 2014 12:13 AM
    Well it doesnt work on the cli
    I don tsee it on the GUI neither...
    Unless is not suppported on 620 controllers? but it doesnt say anything about that or at least i don tsee it.
    (Office_Alternetworks) (config) #show version
    ArubaOS (MODEL: Aruba620), Version 6.3.1.4
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2014, Aruba Networks, Inc.
    Compiled on 2014-03-18 at 14:59:06 PDT (build 42768) by p4build
    ROM: System Bootstrap, Version CPBoot 1.0.0.0 (build 23274)
    Built: 2010-01-19 11:11:41
    Built by: p4build@re_client_23274
    Switch uptime is 23 hours 52 minutes 1 seconds
    Reboot Cause: User reboot.
    Supervisor Card
    Processor XLS 204 (revision A1) with 928M bytes of memory.
    32K bytes of non-volatile configuration memory.
    256M bytes of Supervisor Card System flash (model=NAND 256MB)
    Well this is odd...
    Cheers
    Carlos
  • 20.  RE: Clearpass profiler doesnt seems to be working...
    Posted Mar 30, 2014 12:19 AM
    Well i just found it
    ftp://ftp.afina.es/Aruba/Aruba_OS/UPGRADE_3000_6.3.1.1-ArubaOS/ArubaOS%206.3.1.1%20RN.pdf
    The ifmap is not supported on 6xx  like many other features :P now im starting to hate 620s :)
