ClearPass profiler errors in event log
  • 1.  ClearPass profiler errors in event log
    Posted May 09, 2023 08:40 AM
    We're seeing the following profiler errors occurring on a regular basis within the event log of each ClearPass node (4).
    However, the error is lacking detail but reports that the box is 'unstable'.
    Does anyone have any idea of what these errors mean?
  • 2.  RE: ClearPass profiler errors in event log
    Posted May 09, 2023 10:04 AM
    What version are you running ?
    6.10.x?
    Sent from my iPhone
  • 3.  RE: ClearPass profiler errors in event log
    Posted May 09, 2023 10:43 AM
    If you’re running 6.10.8, then you need to install HotFix patch 5 which includes the HD2 profiler error patch
    If you’re running 6.11 then. You need too wait till 6.11.3
    A
  • 4.  RE: ClearPass profiler errors in event log
    Posted May 09, 2023 11:40 AM
    Thanks, we're running 6.10.8.
    Is there any further information on what the profiler errors are?
  • 5.  RE: ClearPass profiler errors in event log
    Posted May 12, 2023 04:57 AM
    It's a check if profiling is working correctly, and in some cases the error is cosmetic, in other cases the profiling stops. For 6.10.8, I believe the latter is the case, so if you use profiling and don't see new profiling data coming in, install the hotfixes.
  • 6.  RE: ClearPass profiler errors in event log
    Posted May 12, 2023 05:18 AM
    TAC said the profiling issue will be fixed in 6.11.3
    A
