Clearpass Profiler Inquiry?
  • 1.  Clearpass Profiler Inquiry?
    Posted Sep 12, 2015 11:34 AM
    I'm using HP wired Switch 802.1x and I see endpoints profiler is not profiled so I wanted to know what may be the problem I want to know if thsi configurations is right ,also what is the right enforcment should be done ?
    Role name :Unknown Device
    Role-Mapping
    (Authorization:[Endpoints Repository]:Category  NOT_EXISTS   )     Unknown Device
    Endorcment Policy
    tips role equals [user auuthenticated]
    tips role equals 802.1x authentication
    tips role equals unknow device
  • 2.  RE: Clearpass Profiler Inquiry?
    Posted Sep 12, 2015 11:36 AM
    Do you have helper addresses configured on the L3s?
    Tim
  • 3.  RE: Clearpass Profiler Inquiry?
    Posted Sep 12, 2015 11:55 AM
    so you said that I have do IP helper address pointing to clearpass IP on the Interface VLAN?
  • 4.  RE: Clearpass Profiler Inquiry?
    Posted Sep 12, 2015 11:58 AM
    Yes. Whichever interface is the client's DG, should have a helper address. Sometimes this is upstream of the edge switch..
    Tim
  • 5.  RE: Clearpass Profiler Inquiry?
    Posted Sep 12, 2015 12:05 PM
    One more thing Mr tim what VLAN Enforcment should be the Action for the unknown device?
  • 6.  RE: Clearpass Profiler Inquiry?
    Posted Sep 12, 2015 12:08 PM
    You would want to return a dynamic ACL that only allows DHCP.
    Tim
  • 7.  RE: Clearpass Profiler Inquiry?
    Posted Sep 12, 2015 12:13 PM
    so for HP Switch what type of enforcment type can do this?
  • 8.  RE: Clearpass Profiler Inquiry?
  • 9.  RE: Clearpass Profiler Inquiry?
    Posted Sep 12, 2015 07:33 PM
    damm, these TechNotes are pretty useful, shame that guy that wrote then never gets any Kudos...!!!!!......LO(very)L......
