Import through API or XML will not set profiling information. It does set the Known/Unknown status, and you can import attributes. The original question was just about setting the Known flag, which works. You may see expected behavior, if you only set profiling data.
Profiling data is what is discovered by the system, and may change if the device changes, so there is a design reason why you can't import profiling attributes.
If you also want to set the device type, you could do that through a device attribute and test that in your policy; or as mentioned earlier use the Guest Device Database, which is similar on setting attributes but in a slightly different form. If you need to have non-admins manage the device registrations, using the Guest Device Database is probably the best option; if it is just admins or API access the Endpoint Database is a good choice.
Original Message:
Sent: Sep 13, 2022 03:08 AM
Subject: Clearpass - Profiling/Importing fixed ip address device
It does not work. When XML populated with new mac addresses who never recognized by clearpass before, endpoint repository won't take it. Only mac addresses are imported.
Original Message:
Sent: Sep 04, 2022 10:58 PM
yes you can import them through XML import.
you can export one to see the XML formatted file
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/5404126e79fa4e4a8bd066d0e0d2b369.png)
https://www.arubanetworks.com/techdocs/ClearPass/6.9/PolicyManager/Content/CPPM_UserGuide/Admin/EndpointsHelp.html
Original Message:
Sent: Sep 04, 2022 08:41 PM
Hello everyone,
We have a number of existing CCTV currently with fixed ip address and would like to import to clearpasss to setup mac-authentication with the switch user role.
Just wondering if I can do a bulk import to the endpoints database without going through the device profiling.
Can I categories it or set up some attribute to mark those as "permitted known" device"?
I believe device profiling is more suitable for new devices.
However, I still want put some control to the "unknown" device so it will not be assigned to the same user role as the "known" device automatically.
Thanks in advance for any suggestion.
