Clearpass question about VIP/FQDN
  • 1.  Clearpass question about VIP/FQDN
    Posted Nov 11, 2019 02:56 AM
    Hi all,
    Just a few quick questions.
    1. When im using a VIP address, Is it still best practice to point to each node ip in de switch as radius server and iphelper for profiling?
    2. When using a cluster, i want to use FQDN as the CN in my certificate. Do i need to get the FQDN the same on all nodes on the cluster or is there a special config for a "cluster FQDN"?
    Thank you
  • 2.  RE: Clearpass question about VIP/FQDN
    Posted Nov 11, 2019 03:41 AM
    1. Yes, you should configure your NADs to point each individuals ClearPass servers. VIP is good to for captive portal workflow. Please see : https://community.arubanetworks.com/t5/Security/ClearPass-Cluster-with-VIP-or-not/td-p/299261
    2. I would advice to use a common CN for RADIUS Certificate like radius-clearpass.domain.tld and install this certificate on each cppm.
    For HTTPS certificate, you can create one for each clearpass using the fqdn as the CN : fqdn1.domain.tld for cppm1, fqdn2.domain.tld for cppm2, etc.
    Cheers
