Clearpass RADIUS/EAP certificate switchover
  • 1.  Clearpass RADIUS/EAP certificate switchover
    Posted Nov 08, 2019 06:43 AM
    Hi all,
    The certificate we currently use for RADIUS/EAP on one of our SSIDs is expiring.  We already have the new one and ideally want to do an overlapping service using the new one in parallel to give devices chance to migrate, and so we can see what is still to migrate.
    With PEAP this has been fairly simple, we've specified an outer identity on reconfigured clients, and then created a new service definition in Clearpass that looks for a Radius:IETF Username of this specified identity and offered the new certificate if it's found.  Sadly we've not previously used outer identities for identification, so it's a case of "look for this attribute, if found use new service, if not found use old".
    The issue we've now hit is with EAP-TLS clients.  The supplicants don't seem to pass the outer identity (even though some research has confirmed it's in the spec) and as such we're a bit stuck how to stop these from dropping through to the old service.  Looking at the Radius attributes of the requsts I was hoping to see something I could differentiate on but sadly there's nothing.  No EAP-TLS clients should be using the old service anyway (as they're the easy ones to switch over) so if I could somehow have three services, one that only listens to EAP-TLS, one that listens to PEAP with the outer identity and then the fallback that just listens to PEAP with no outer identity requirement that would be ideal.  However, setting up a service with the constraint of "Radius:Aruba > Aruba-Essid-Name > OurSSID" that only listens to EAP-TLS would immediately catch and fail all the PEAP ones to.  Is anyone aware of a way to do a fall through on this, so that if a PEAP request comes in it bypasses the first service and moves onwards?
    Cheers,
    Luke
  • 2.  RE: Clearpass RADIUS/EAP certificate switchover
    Posted Nov 08, 2019 07:23 AM
    Are you planning to use the same CA and common name when you generate the new cert?
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Clearpass RADIUS/EAP certificate switchover
    Posted Nov 11, 2019 10:46 AM
    Ah if only it was that simple, different CA, different CN.  Who wants an easy life after all ;)
