clearpass redirection time out
  • 1.  clearpass redirection time out
    Posted Dec 09, 2014 12:07 PM
    I've setup an external captive portal redirect to a web logon page using https://ase.arubanetworks.com/solutions/id/3
    I imported the setting just fine. I get dhcp, dns all fine. But when the redirect kick in, it returns a message stating that clearpass took to long to reply and times out.
    Iders?
  • 2.  RE: clearpass redirection time out
    Posted Dec 09, 2014 07:38 PM
    Guys, here is the config I created:
    #Create SSID profile
    wlan ssid-profile "tpl-Mountcom_guest_access"
      essid "Mountcom_guest_access"
      opmode opensystem
      exit
    aaa authentication-server radius "tpl-Mountcom_guest_access"
      host "10.17.2.30"
      key "aruba123"
    aaa rfc-3576-server "10.17.2.30"
      key "aruba123"
    aaa server-group "tpl-Mountcom_guest_access"
      auth-server "tpl-Mountcom_guest_access"
    aaa profile "tpl-Mountcom_guest_access"
      radius-accounting "tpl-Mountcom_guest_access"
    #Create an ACL that allows the unauthenticated guest to reach the external captive portal page.
    netdestination "tpl-Mountcom_guest_access-allow-external-captive-portal"
      no invert
      host 10.17.2.30
      exit
    ip access-list session "tpl-Mountcom_guest_access-allow-external-captive-portal"
      user alias "tpl-Mountcom_guest_access-allow-external-captive-portal" svc-http  permit
      user alias "tpl-Mountcom_guest_access-allow-external-captive-portal" svc-https  permit
      exit
    #BEGIN - Create ACL's for the unauthenticated guest before they log in on the captive portal.  These provide basic network access and cause the captive portal redirect.
    ip access-list session "tpl-Mountcom_guest_access-cplogout"
      user   alias controller svc-https  dst-nat 8081
      exit
    #Allow basic network access such as DNS and DCHP but deny the user from acting as a DHCP server.
    ip access-list session "tpl-Mountcom_guest_access-logon-control"
      user any udp 68 deny
      ipv6 user any icmpv6 rtr-adv deny
      any any svc-icmp permit
      any any svc-dns permit
      any any svc-dhcp permit
      any any svc-natt permit
      exit
    ip access-list session "tpl-Mountcom_guest_access-captiveportal"
      user any svc-http dst-nat 8080
      user any svc-https dst-nat 8081
      user any svc-http-proxy1 dst-nat 8088
      user any svc-http-proxy2 dst-nat 8088
      user any svc-http-proxy3 dst-nat 8088
      exit
    #END - Create ACL's for the client before they log in on the captive portal.  These provide basic network access and cause the captive portal redirect.
    #Create a logon user role with the ACL restrictions.
    user-role "tpl-Mountcom_guest_access-logon"
      exit
    #BEGIN - Create ACL's to restrict authenticated guest user from accessing internal networks.  Only allow HTTP/HTTPS access to public sites.
    netdestination "tpl-Mountcom_guest_access-internal-net"
      network 10.0.0.0 255.0.0.0
      network 172.16.0.0 255.240.0.0
      network 192.168.0.0 255.255.0.0
      exit
    ip access-list session "tpl-Mountcom_guest_access-block"
      user alias "tpl-Mountcom_guest_access-internal-net" any deny
      exit
    ip access-list session "tpl-Mountcom_guest_access-authenticated"
      any any svc-http permit
      any any svc-https permit
      exit
    ip access-list session "tpl-Mountcom_guest_access-drop-all"
      user any any deny log
      exit
    #END - Create ACL's to restrict authenticated guest user from accessing internal networks.  Only allow HTTP/HTTPS access to public sites.
    #Create a post authenticated user role that has limited network access.
    user-role "tpl-Mountcom_guest_access"
      exit
    aaa authentication captive-portal "tpl-Mountcom_guest_access"
      login-page "https://10.17.2.30/guest/weblogin.php/3?_browser=1"
      welcome-page "/auth/welcome.html"
      no guest-logon
      no logout-popup-window
      redirect-pause 3
      default-role "tpl-Mountcom_guest_access"
      exit
    aaa authentication mac "tpl-Mountcom_guest_access"
      exit
    #Attach the captive portal profile to the logon user role
      exit
    #Set the initial user role to the logon user role that enabled captive portal.
      initial-role "tpl-Mountcom_guest_access-logon"
    #Apply the MAC authentication profile to support MAC caching.  Successfully authenticated MAC addresses will bypass the captive portal login and get immediate access.
      authentication-mac "tpl-Mountcom_guest_access"
      mac-server-group "tpl-Mountcom_guest_access"
      mac-default-role "tpl-Mountcom_guest_access"
      exit
    #Create VLAN and VLAN Properties.
    vlan 230
    interface vlan 230
      ip address 10.230.0.31 255.255.252.0
    #DHCP Helper is used for Policy Manager "Profile" feature
      ip helper-address "10.17.2.30"
      exit
    #Create DHCP Pool
    ip dhcp pool "tpl-Mountcom_guest_access"
      default-router 10.230.0.31
      dns-server 8.8.8.8 8.8.4.4
      network 10.230.0.0 255.255.252.0
      domain-name Mountcom.com
      exit
    #Enable DHCP service
    service dhcp
    wlan virtual-ap "tpl-Mountcom_guest_access"
      aaa-profile "tpl-Mountcom_guest_access"
      vlan 230
      exit
    ap-group "FirstFL_Basement"
      exit
    end
  • 3.  RE: clearpass redirection time out
    Posted Dec 09, 2014 07:57 PM
    The address should end with .php. Is there a reason why you have the rest? Also for testing its best to disable https on both the controller and clearpass. Make sure you also remove it from the redirect address.
      no guest-logon
      redirect-pause 3
      exit
