Higher Education
last person joined: 24 days ago
Got questions on how to enable mobility in education? Submit them here!
ClearPass Report
  • 1.  ClearPass Report
    Posted Sep 24, 2015 12:21 PM
    How do you setup an alert in Insight that provide you with the following:
    Alert you if there is more than 100 Failed Authentication within 5 minutes. The goal is the create an alert that you let you know that there might be a radius or authentication or ad issues becuase large amount of users are unable to authenticate agaist clearpass.
    When you use the default template in Insight: Radius Failed Authentication You can select Threshold  and Interval. However, this alert only give you the amount of failed auth Accumulated in a internal so you might get 10 or 25 failed authentication but this does not mean necessariliy that there is a problem.
    Should i use airwave instead?
    Thank you
    Nils
  • 2.  RE: ClearPass Report
    Posted Sep 24, 2015 12:22 PM
    Do you use Splunk?
    Tim
  • 3.  RE: ClearPass Report
    Posted Sep 24, 2015 12:27 PM
    I am currently using the free version and works great! Company hasnt bought the full subscription yet so i was wondering i can get an alert using clearpass in the meantime.
    Thank you
  • 4.  RE: ClearPass Report
    Posted Sep 24, 2015 12:32 PM
    You can use AirWave for now. Once you get full Splunk, there is a full ClearPass app for it.
    Tim
  • 5.  RE: ClearPass Report
    Posted Sep 24, 2015 12:36 PM
    That would be a good argument for me to convience top mgnt to release the budget. Thank you. Is there is a guide that talk about the integration of Splunk with ClearPass?
  • 6.  RE: ClearPass Report
    Posted Sep 24, 2015 12:38 PM
    There is a technote on the support site.
    Tim
  • 7.  RE: ClearPass Report
    Posted Sep 24, 2015 12:39 PM
    If you have access to solution exchange.
    https://ase.arubanetworks.com/solutions/id/70
  • 8.  RE: ClearPass Report
    Posted Sep 24, 2015 05:18 PM
    You can easily setup the alert in insight. I will try to post a screen shot when my flight lands or if we ask really nice Tim or Victor can log into my lab and grab a screen shot of my tacacs alert. :)
  • 9.  RE: ClearPass Report
    Posted Sep 24, 2015 05:32 PM
    See the attached screenshot that Troy was talking about. Just change it to RADIUS instead of TACACS
  • 10.  RE: ClearPass Report
    Posted Sep 24, 2015 05:34 PM
    Thank you sir.
  • 11.  RE: ClearPass Report
    Posted Sep 28, 2015 04:27 PM
    Thank you
    I modified the Rule. Image attached. Just to confirm.
    The internval means: During a 1 minute check if there is any Auth Failure
    Thrreshold: Check for 5 Auth Failures
    Am i correct?
  • 12.  RE: ClearPass Report
    Posted Sep 28, 2015 07:33 PM
    Correct. If there is more than 5 auth fails in one min then send notice
  • 13.  RE: ClearPass Report
    Posted Oct 02, 2015 09:15 AM
    Does anyone know how  to change the alert email date format:
    Alert [Radius Failed Authentications] between 02/10/2015 07:19 and 02/10/2015 07:39
    2015-10-02 07:23:59-04:00    mt823           err:User authentication failed
    2015-10-02 07:24:26-04:00    mt823           err:User authentication failed
    2015-10-02 07:25:28-04:00    mt823           err:User authentication failed
    2015-10-02 07:27:24-04:00    mt823           err:User authentication failed
    2015-10-02 07:29:20-04:00    mt823           err:User authentication failed
    2015-10-02 07:29:50-04:00    lc599           err:User authentication failed
    2015-10-02 07:30:13-04:00    mt823           err:User authentication failed
    As you can see the current format is day/month/year and I would like to change it to month/day/year.
    Nils.
  • 14.  RE: ClearPass Report
    Posted Oct 02, 2015 09:53 AM
    It is not a changeable field.
  • 15.  RE: ClearPass Report
    Posted Oct 02, 2015 09:59 AM
    Thank you Troy
  • 16.  RE: ClearPass Report
    Posted Sep 24, 2015 12:25 PM
    I've been using Airwave and it works great.
    'Client RADIUS Authentication Issues' for Type
    Duration 5 minutes
    Count >= 100
    I have it send an e-mail.
