ClearPass reporting : AppRF support for guests
  • 1.  ClearPass reporting : AppRF support for guests
    Posted Sep 29, 2015 03:12 PM
    Hi all.
    I am making a test deployment ClearPass 6.5 now. Is there any means to get a report which contain visited URLs for particular guest account? I know that AirWave has similar feature(through the using of AppRF), but there's not a word about it in the ClearPass Insight.
    If it is not possible by builtin tools/templates, maybe there is some other way to do it?
  • 2.  RE: ClearPass reporting : AppRF support for guests
    Posted Sep 29, 2015 03:13 PM
    That would be done in AirWave.
    Tim
  • 3.  RE: ClearPass reporting : AppRF support for guests
    Posted Sep 29, 2015 04:09 PM
    But how can I get from AirWave some personal information about guest,
    particularly his cell phone number?
  • 4.  RE: ClearPass reporting : AppRF support for guests
    Posted Sep 29, 2015 04:11 PM
    You wouldn't. You would search the MAC address or username in ClearPass Guest.
    Tim
  • 5.  RE: ClearPass reporting : AppRF support for guests
    Posted Sep 29, 2015 04:45 PM
    Thank you, Tim!
    Just to make all things clear - is there some simple way to bind guest usernames from AirWave to ClearPass Guest? Or I have to get two reports - one from AirWave and other from Insight and just compare them with some external software?
  • 6.  RE: ClearPass reporting : AppRF support for guests
    Posted Sep 29, 2015 04:50 PM
    Usernames from ClearPass Guest will be passed to the controller and then will appear in AirWave. If you need additional information beyond basic information from a RADIUS request, then you would need to correlate the data in ClearPass Guest.
  • 7.  RE: ClearPass reporting : AppRF support for guests
    Posted Sep 29, 2015 05:05 PM
    Ok, thanks!
