last person joined: 9 hours ago
Clearpass Reports HTML
  • 1.  Clearpass Reports HTML
    Posted Aug 28, 2019 04:28 PM
    Good morning From the Insight module in Clearpass it is possible to generate reports, where we can modify, add and remove some columns when extracting them in CSV. Additionally, the report is generated in PDF format and another one in HTML quite similar. My question is, if there is any way to edit the information that appears in the reports in HTML or PDF; since there is certain information that is not relevant for the client and can cause confusion. I enclose an image, where users and MAC addresses are shown in the HTML report. My intention is that only users leave in this report. Any contribution is valued.
  • 2.  RE: Clearpass Reports HTML
    Posted Sep 04, 2019 05:06 AM
    You should be able to raise a TAC case and ask for a custom template where you can request a removal of these. It may work. Let us know how it goes.
