last person joined: 8 hours ago
Clearpass rlm_mschap: detach
  • 1.  Clearpass rlm_mschap: detach
    Posted Nov 29, 2015 10:23 PM
    Hi Guys,
    i'm having an issue with one of my clearpass in my customer's site.
    clearpass is authenticating PEAP-MsChapv2 with data source from AD.
    everythhing used to be working fine but lately sometime some users always failed to authenticate with error msg: (i use syslog debug)
    [main] INFO  RadiusServer.Radius - rlm_mschap: detac
    [main] INFO  RadiusServer.Radius - rlm_sql (auth_local_db): Driver rlm_sql_unixodbc (module rlm_sql_unixodbc) loaded and linked
    [main] INFO  RadiusServer.Radius - rlm_sql (auth_local_db): Database to connect to appuser@localhost:/tipsd
    i'm guessing the error msg appears as if the clearpass is un-joined from the AD but it actually already and still is..
    the only fix i got is by making the clerpass to leave the AD and rejoin.
    this has been done several times.
    any pointer what should be done to avoid this issue?
    Ricky
  • 2.  RE: Clearpass rlm_mschap: detach
    Posted Dec 26, 2015 07:23 AM
    are you basing this only on: [main] INFO  RadiusServer.Radius - rlm_mschap: detac  ?
    i would contact support, they can probably much better pick up on issues if they get the full debug logs.
