Clearpass Self-Registration Chance Username default Emailadress
  • 1.  Clearpass Self-Registration Chance Username default Emailadress
    Posted Oct 04, 2013 05:43 AM
    Hi
    i hope this is just a simple question but i can't find the right option in the clearpass.
    On Self-Registration the guest emailadress is used as login username by default.
    I want to change it. I want to use the cellphone number as username.
    Can you tell me on which section it is configured?
    Thanks a lot
  • 2.  RE: Clearpass Self-Registration Chance Username default Emailadress
    Posted Oct 04, 2013 06:52 AM
    Hi Florian,
    I have configured cell phone number as username at one of our customer site:
    - Disable the "visitor_phone" field at the registration page.
    - Add "username" field and change its label as "Phone Number"
    - Inside this username field, select "NwaSmsIsValidPhoneNumber" as validator and "NwaNormalizePhoneNumber" as conversion.
    - Finally under the SMS receipt tab, select username at Phone Number Field.
  • 3.  RE: Clearpass Self-Registration Chance Username default Emailadress
    Posted Oct 04, 2013 07:15 AM
    but is this the only way?
    It sounds like not like the common way to solve this problem.
    Where is the link between username und emailadress?
  • 4.  RE: Clearpass Self-Registration Chance Username default Emailadress
    Posted Oct 04, 2013 07:52 AM
    Probably I made this configuration 3 or 4 months ago, and as I would recall correctly, one of the Aruba engineer told me that if "username" field is used at the registration page, clearpass uses the value in this field and you can change the display settings for this field as you want (In our scenario, we used the same settings as "visitor_phone" field). If there is no "username" field at the register page, than clearpass uses e-mail address as a username.
