ClearPass server not sending syslog messages
This thread has been viewed 16 times
  • 1.  ClearPass server not sending syslog messages
    Posted Jul 06, 2017 05:53 PM
    I've followed the User Guide by creating a new export destination server and then creating several syslog export filters.  I made sure to select the right syslog export destination as well as the subscriber servers I want to send logs from.  The destination server does not appear to be receiving anything despite me seeing several accounting messages on CPPM's access tracker.
    I ran a packet capture on the port leading to the CPPM server in question that is authenticating users, but I don't see any traffic coming out of it destined for the export destination.  I've specifically create several RADIUS/TACACS+ policies and included all the available options under the filter, so I'm not sure what is wrong at this point.
    All of my syslog export filters are shown as Enabled.
  • 2.  RE: ClearPass server not sending syslog messages
    Posted Jul 07, 2017 05:13 AM
    Hi Patrick,
    We need to check syslogs to see why Clearpass is not able to export the logs to exteranl server, for this we need CLI access.
    If you are using any ASCII characters in password, try reset the cluster password once without any special characters from Administration » Server Manager » Server Configuration  > Change Cluster password and check the status, if that does not reslove, please open TAC ticket to troubleshoot the issue further.
    Pavan
  • 3.  RE: ClearPass server not sending syslog messages
    Posted Jul 07, 2017 02:31 PM
    I've created some dump logs to review and I can't seem to find a reason why this is happening.  I was able to collect them from the web UI by going to Configuration -> Server manager -> Server configuration, then clicking the radio button for the server I wanted logs from and clicking Collect Logs.
    What log file in the .tar.gz package contains the information on why this would be failing?
  • 4.  RE: ClearPass server not sending syslog messages
    Posted Dec 14, 2017 09:01 PM
    did you end up resolving this? i'm experincing similar issue with 6.6.8
  • 5.  RE: ClearPass server not sending syslog messages
    Posted Jan 08, 2018 07:20 AM
    Same problem here.  It was working and then just stopped overnight for no apparent reason.  I haven't been able to get the logs going since.
  • 6.  RE: ClearPass server not sending syslog messages
    Posted Feb 15, 2019 07:24 AM
    Hi Patrick,
    did you ever resolve this problem? I followed the same procedure and I too can not see any traffice from the CPPM
  • 7.  RE: ClearPass server not sending syslog messages
    Posted Feb 15, 2019 08:20 AM
    Have you configured syslog targest and syslog export filter, if yes does port is allowed between CPPM and syslogn targets ?
    You can take packet capture from Administration » Server Manager » Server Configuration and see if anything is  blocking the traffice.
  • 8.  RE: ClearPass server not sending syslog messages
    Posted Feb 15, 2019 08:48 AM
    Hello Pavan,
    Thank you for the quick response. I did all the above and have allowed udp 514 from the cppm to the target sever. I captured pakets from cppm and checked the ACL closest to the CPPM and did not see any packets destined to UDP 514. I did capture the Log from Administration » Server Manager » Server Configuration but could not determine which file to look into. I though it would be a file I would use with wireshark. I went through most of the logs but did not see anything in particular destined to syslog
  • 9.  RE: ClearPass server not sending syslog messages
    Posted Feb 15, 2019 09:22 AM
    check highlighed box to get packet capture file
  • 10.  RE: ClearPass server not sending syslog messages
    Posted Feb 15, 2019 02:18 PM
    I did download a capture and do not see any traffic destined to the syslog udp 514.
  • 11.  RE: ClearPass server not sending syslog messages
    Posted Feb 15, 2019 04:18 PM
    Mkaroki, what version of ClearPass are you running? What kind of SYSLOG messages are you trying to send to your server? Session Logs? System Events? Audit Records? If just Session Logs, try System Events and Audit Records to see if you receive a different outcome.
  • 12.  RE: ClearPass server not sending syslog messages
    Posted Feb 15, 2019 04:31 PM
    Do you have the actual syslog export filters enabled?
    Is insight enabled?
    Get Outlook for Android
  • 13.  RE: ClearPass server not sending syslog messages
    Posted Feb 19, 2019 12:03 PM
    Thank you all for your input in troubleshooting this. I have successfuly sent syslog information from CPPM. I deleted all the export filters and rebuilt them. I was however directed to disable and renable the filter by pressing the green status bubble and again the red status bubble to enable. That seem to have worked.
    Again this was on ClearPass Policy Manager 6.7.8.
