Clearpass Service with two autentication methods differents for two operating system.
  • 1.  Clearpass Service with two autentication methods differents for two operating system.
    Posted Oct 26, 2016 09:51 AM
    I have an environment with Windows 7, 10, vista and XP.
    My service has a EAP TLS as authentication mode, but my XP systems is not connecting in that service.
    I would like to know, if can I insert a MS-CHAP V2 in the service as authentication mode and force the xp systems to use this method in roles?
  • 2.  RE: Clearpass Service with two autentication methods differents for two operating system.
    Posted Oct 26, 2016 09:53 AM
    Short answer: yes, you can support multiple EAP methods on the same SSID.
    Question: Is the Windows XP client configured for EAP-TLS?
  • 3.  RE: Clearpass Service with two autentication methods differents for two operating system.
    Posted Oct 26, 2016 11:20 AM
    • Edit your service and go to the Authentication tab.
    • Under the "Authentication Methods" section click the "-- Select to Add--" dropdown box
    • Add whatever other methods you need.
  • 4.  RE: Clearpass Service with two autentication methods differents for two operating system.
    Posted Oct 26, 2016 11:39 AM
    Hi my friend,
    I don't want to user TLS for XP devices, I qant to configure for MSCHAP-V2 but if I put the EAP-MSCHAP-V2 in the authentication methods, other devices will can connect too.
    I need a way that only XP can be connect by EAP-MSCHAP-V2.
  • 5.  RE: Clearpass Service with two autentication methods differents for two operating system.
    Posted Oct 26, 2016 11:54 AM
    Not necessarily, it depends on how you configure the your clients and how you configure your service.
    If you configure your other devices to use EAP-TLS, then they will only use EAP-TLS and not EAP-MSCHAPv2.
    If you want to be really strict though, you could figure out of a way of identifing what OS the device is using (probably through the Endpoints database) and then use a roll mapping and enforcement to block the device if it is not using the EAP method you want.
    So for instance, if you have a Windows 10 device and it tries connecting using EAP-MSCHAPv2, then it will be denied. You would then need to identify why the device is using EAP-MSCHAPv2 vs EAP-TLS.
    On a side note, the authentication methods defined in the service do not dictate what method your client uses, it only indicates what authenticaiton methods the service will process or handle.
  • 6.  RE: Clearpass Service with two autentication methods differents for two operating system.
    Posted Oct 26, 2016 12:27 PM
    I think that is the way.
    I will try to configure it and will report here.
