Using SMS via SMTP to text guest accounts to users. The bottom of the text says: Powered by Aruba
what form/field do I need to edit to remove or edit this?
ahhh.. the one section I didnt look... thanks!
Yeah, it's a bit confusing under "Print"
Trying to disable the role ID on the form to create guest passes.. I disabled the field and now get
