Clearpass Social Login - october-mhc
  • 1.  Clearpass Social Login - october-mhc
    Posted Oct 06, 2014 05:21 AM
    Hi gang!
    (first post dissapeared so I'm trying to post this one more time..)
    This isn't a complete step-by-step tutorial as it expects you to know your way around the Aruba WLC and Clearpass configuration elements. Some snippets of this I got from our awsome community, but key elements was still missing and took some hours in the lab to work out. As we gain more experience with this authentication I will add more to this tutorial.
    Requirements
    You will need Clearpass 6.4.x as that is where the "true" social-login support started. It's possible to do with some 6.3.x version, but I wouldn't recommend it as I believe that was mostly for Aruba internal testing/showcasing.
    Facebook
    When it comes to using Facebook as authentication you will need access to a facebook account. With this account you first register as a developer (free and open for all) using this URL: https://developers.facebook.com. This is the account you will be creating your authentication app with.
    During your testing the authentication APP you create will not be LIVE. Only the facebook account you use for creating the App and the people you invite will be able to suceesfully authenticate using this Facebook social-login. The facebook users you invite will receive a message with the invite. They will first have to register as devolopers before being able to accept the invitation.
    Note! I haven't actually gotten past the Developer status of my facebook Auth App, but will update once I figure out how thats accomplished. For instanse - making it necessary to Like a certain page is something I'm definately looking into, but havent found out how is done yet.
    Clearpass, IP or FQDN
    It seems that you can not be using an IP address in your redirect as this returns an error message from Facebook during the auth process. That means you will have to create a DNS entry that is resolvable for your guests.
    Whitelisting social websites
    For this to work you will have to accept that un-authenticated users will be able to surf on Facebook. There is no way around that, so if thats against your policy then this is a no go for you. This is not only for facebook, but for all forms of social login
    The setup
    On Controller
    If you have a usable ClearPass guest SSID already then you can use that. Just add the necessary fw rules to your -logon role.
    Create a Open Guest SSID with required aaa, vap, captive portal, ssid etc.
    • Initial role - social-logon (create new)
    • Captive Portal redirect to Clearpass
    FW policy for -logon role:
    • logon-control (or your variant of it)
    • social-list-operations:
             -> Permit http/https towards the social media auth servers (see Alias list below) AND the Clearpass server
    Aliases for facebook
    • social-facebook (minimum required at this time)
    • graph.facebook.com
    • api-read.facebook.com
    • api-video.facebook.com
    • www.facebook.com
    • fbstatic-a.akamaihd.net
    • fbcdn-profile-a.akamaihd.net (new?!)
    • fbexternal-a.akamaihd.net (new?!)
    My suggestions incase this changes in the future:
    • facebook.com
    • akamaihd.net
    On Clearpass
    Guest
    If you already have a working login page - just use that and add the snippet below.
    • Create web login with custom login form (this is the one you redirect to)
    • Check for Social Login, and enter the ones you want to be able to login with.
    For each social login type you will have to add the AppID and AppSecret. If you have these already then add them - if not come back to this after you've created the App in the Facebook sections below.
    In the footer add this snippet
    {nwa_social_logins}
    • See more versions you can use in the "Other things" section below.
    CPPM
    Create Auth Source
    I'm assuming this will change in a near release so we can just select social-login as type when creating Auth source, but this is it for now.
    • Create a New Auth source with type "Generic SQL"
    • Check use for Authorization
    See screenshot for setup (All Social data is stored in the Endpoints database connected to the device so thats why we use it for authentication)
    • Under Attributes create two Filters: Authentication and Social Service Provider
    Fidn the SQL to use as input for Filter Query under "Other things" section in this doc.
    Create the Service
    Use your existing working Guest service or create a new server.
    Easiest way is to use the wizard and create a new Guest Access service. The templates "Guest Access" or "Guest access with MAC auth" will get the job done nicely. Or - just .
    • Add the Social Auth source as authentication source to the Guest Access service
    • Optional: add a test and return various roles depending on the social-source. Might make it easier for statistics this way
    Facebook
    Now you need to login to developers.facebook.com and create the App
    • Click Apps - Register new App
    Note! (Just refresh site a few times if it still shows Register as developer if you just registered)
    • Click Apps - Register new App (refresh site if it still shows Register as developer)
    Apps -> "Your Auth App"
    1. Settings - Basic.
    2. Add the name (FQDN) of your clearpass server under App Domains
    3. Add Platform and select Website
    4. In "Site URL" input the whole URL for your loginpage on Clearpass
    5. Save
    Now - note down the App ID and App Secret for this app. You will need this when adding social login to your login page on Clearpass.
    Before you go live with the app you will want to go through the App settings - Advanced section to improve security.
    Testing
    Now it's time to test things out. You should already have the SSID running so just load up your favorite device and connect to the SSID. You should now see something similar to this:
    Click Facebook and you should be be redirected to Facebook. Depending on your device and facebook integration you will either be asked for Facebook credentials or immediately a prompt that wants you to authorize "your auth app" for access to a few personal details
    Things to check when it doesnt work..
    • Make sure you are using a facebook account that have test access to your App.
    • Re-check the inputs you have entered into the FB App
    • Verify that normal guest login works before troubleshooting more
    • Check Access Tracker. Verify that the correct service is triggered.
    Other Things...
    Auth SQL input
    Filter Query - Authentication:
    SELECT tag_value AS User_Password FROM tips_endpoint_tag_mappings  JOIN tips_tag_values ON (tips_endpoint_tag_mappings.tag_value_id = tips_tag_values.id) WHERE tips_endpoint_tag_mappings.instance_id =      (SELECT id       FROM tips_endpoints      WHERE mac_address = LOWER('%{Connection:Client-Mac-Address-NoDelim}'))          AND tips_tag_values.tag_id =               (SELECT id               FROM tips_tag_definitions               WHERE name = 'social_password'                    AND entity_id =                        (SELECT id                         FROM tips_dic_internal                        WHERE dic_prefix = 'Endpoint'));
    Filter Query - Social Service Provider
    SELECT tag_value AS SP FROM tips_endpoint_tag_mappings  JOIN tips_tag_values ON (tips_endpoint_tag_mappings.tag_value_id = tips_tag_values.id) WHERE tips_endpoint_tag_mappings.instance_id =      (SELECT id       FROM tips_endpoints      WHERE mac_address = LOWER('%{Connection:Client-Mac-Address-NoDelim}'))          AND tips_tag_values.tag_id =               (SELECT id               FROM tips_tag_definitions               WHERE name = 'social_method'                    AND entity_id =                        (SELECT id                         FROM tips_dic_internal                        WHERE dic_prefix = 'Endpoint'));
    nwa_social_login
    {nwa_social_login}
    The following parameters can be passed:
    vertical=1 to display vertical over horizontal.
    notext=1 to only display icons.
    noicons=1 to only display text.
    noself=1 to suppress logic to include self-registration interlinking.
    prefix='Login with ' to include a prefix on all the labels.
    suffix=' and have fun' to include a suffix at the end of all the labels.
    class=YourClass to give the wrapping div a class a specific class.
    style='color:blue;' to give the wrapping div specific styles.
     Example:
    {nwa_social_logins vertical=1 noicons=1 prefix='Login with ' suffix=' and get access!'}
    Other social aliases
    Linkedin
    New proposal:
    • Linkedin.com
    • Akamaihd.net
    Google
    • www.google.com
    • lh4.googleusercontent.com
    • ssl.gstatic.com
    • accounts.google.com
    References
    Airheads forums in general and especially tarnold. Search for his "social tips" posts.
    afp.arubanetworks.com
  • 2.  RE: Clearpass Social Login - october-mhc
    Posted Jun 03, 2015 04:32 AM
    I am getting error...
    Why?
  • 3.  RE: Clearpass Social Login - october-mhc
    Posted Jul 09, 2015 06:26 PM
    @excrucio, 'mac' must have been passed for social to work.  This will occur in almost all redirects but would not really be there when just testing at the admin level.  You are free to append '?mac=YOURMAC' to that login page.
  • 4.  RE: Clearpass Social Login - october-mhc
    Posted Jul 21, 2015 11:14 PM
    Very nice write up on social login configurations.  I've been searching around for some information on adding a mac-caching feature for social logins, so that subsequent logins will be handled by a mac caching service as is easily done via a sponsor approved method.  Have you heard of any way to cache the mac during the social login process?  Maybe via a post-auth enforcement policy?  I'm just starting to tackle this, but looking for input wherever I can...
  • 5.  RE: Clearpass Social Login - october-mhc
    Posted Jul 21, 2015 11:17 PM
    Here's an example that will allow access for one month before requiring another login:
