ClearPass Solution Fit
  • 1.  ClearPass Solution Fit
    Posted Sep 12, 2014 10:15 AM
    Hope you are all good and smiling :)
    I actually need help identify the solution modules that can offer all of the features mentioned below;
    Access Management
    • Software /Hardware Based Solution
    • Complete network access control and confidentiality solution,
    • Policy-based enterprise network access,
    • Network device administration control, Device administration in IPv4 and IPv6 networks with full auditing and reporting capabilities.
    • AAA protocols Supported (supports RADIUS for network access control and TACACS+ for network device access control),
    • Authentication protocols including PAP, MS-CHAP, Extensible Authentication Protocol (EAP)-MD5, Protected EAP (PEAP), EAP-Flexible Authentication via Secure Tunnelling (FAST), EAP-Transport Layer Security (TLS) and PEAP-TLS to support authentication requirements
    • Access policies user groups, device restrictions, time of day restrictions, VLAN assignments and other access requirements
    • Supports a rules-based attribute-driven policy model,
    • Integration with external identity and policy databases,
    • Integration with existing external identity repositories such as Windows Active Directory and LDAP servers,
    • Supports a completely lightweight web-based GUI that must be easy to use. An efficient, incremental replication scheme quickly propagates changes from primary to secondary systems providing centralized control over distributed deployments.
    • Integrated monitoring, reporting, and troubleshooting component that is accessible through the web-based GUI.
    • Management for minimum 2500 Network Users
    Please advise what exactly i need.
  • 2.  RE: ClearPass Solution Fit
    Posted Sep 12, 2014 10:19 AM
    Please define NAC for your environment. Is that posture/compliance checking?
    Also, are you working with an Aruba or partner SE?
  • 3.  RE: ClearPass Solution Fit
    Posted Sep 12, 2014 11:06 AM
    Thanks for your reply cappalli
    You can consider it a compliance sheet but also need to know what solution best fit against the requirements.
