Clearpass / Soti Integration (MDM Enabled Endpoint tag)
  • 1.  Clearpass / Soti Integration (MDM Enabled Endpoint tag)
    Posted Dec 16, 2013 04:15 AM
    Hi All,
    I've setup the integration between Clearpass and Soti Mobicontrol and am looking at the enformcent policies now.
    I want to use the "MDM Enabled" one that's memtioned in the "Clearpass MDM Integration V2 technote but I can't see it in the list of available options...
    Here's what should be available:
    Here's what I can see:
    Soti integration appears to be ok as I can see nice healthy messages in the event viewer.
    Can anyone help please?
    James
  • 2.  RE: Clearpass / Soti Integration (MDM Enabled Endpoint tag)
    Posted Dec 16, 2013 05:27 AM
    You use Endpoint:MDM Enabled Equals True to check that attribute...
  • 3.  RE: Clearpass / Soti Integration (MDM Enabled Endpoint tag)
    Posted Dec 16, 2013 05:34 AM
    That's what I gathered from the technote however there is no "MDM Enabled" Endpoint tag.
  • 4.  RE: Clearpass / Soti Integration (MDM Enabled Endpoint tag)
    Posted Dec 16, 2013 05:36 AM
    Do you see any devices in the Endpoint database with extended attributes from the MDM?
  • 5.  RE: Clearpass / Soti Integration (MDM Enabled Endpoint tag)
    Posted Dec 16, 2013 05:41 AM
    I can see the following:
    My endpoint with extended attributes.
    and here are my available endpoint tags.
  • 6.  RE: Clearpass / Soti Integration (MDM Enabled Endpoint tag)
    Posted Dec 16, 2013 05:49 AM
    It looks like "mdm enabled" attribute is not being populated, and that might be a bug.  What version of CPPM is this?
    As a workaround you can you use Endpoint: MDM Identifier Exists to check to see if the device is under management?
  • 7.  RE: Clearpass / Soti Integration (MDM Enabled Endpoint tag)
    Posted Dec 16, 2013 05:53 AM
    I'm running CPPM 6.2.2.56621.
    I'll have a go at using the MDM Identifier tag and see how it goes...
    Thanks Colin.
  • 8.  RE: Clearpass / Soti Integration (MDM Enabled Endpoint tag)
    Posted Dec 16, 2013 06:04 AM
    Also you can see my devices shows as compromised in the extended attributes however my device is running a stock ROM and is not rooted.
  • 9.  RE: Clearpass / Soti Integration (MDM Enabled Endpoint tag)
    Posted Mar 31, 2014 09:51 AM
    Did you find a solution to this? /PoTski
  • 10.  RE: Clearpass / Soti Integration (MDM Enabled Endpoint tag)
    Posted Mar 31, 2014 12:02 PM
    Their was a bug identified that was fixed in the 6.3.x code.
    Note: Also fixed in 6.2.5
    From the screen shot you can see that the fields missing have been added into the SOTI endpoint attributes.
