Clearpass Sponsor - Set expiry date when aproving Guest
  • 1.  Clearpass Sponsor - Set expiry date when aproving Guest
    Posted Mar 19, 2015 03:35 PM
    Hi good people!
    Is it possible to allow a Sponsor to set the expiry date when he is aproving the guest access?
    In alternative, is it possible to restrict the guest accounts that a Sponsor can manage? For instance: a sponsor can only manage the accounts he aproved.
  • 2.  RE: Clearpass Sponsor - Set expiry date when aproving Guest
    Posted Mar 19, 2015 10:50 PM
    Do the following:
    1- First edit your guest registration page
    2- Click on the sponsor confirmation page
    2015-03-19 22_38_33-Customize Guest Registration (guest_registration_page).png
    3- Then check the "Display fields to override UI text and labels"
    2015-03-19 22_38_58-Customize Guest Registration (GUEST-REGISTRATION-PAGE).png
    4- Once you select that the option to extend the lifetime of the account for the Sponsor , the you have to enter the Value | Description on each line
    2015-03-19 22_39_33-Customize Guest Registration (GUEST-REGISTRATION-PAGE).png
    It should look like this:
  • 3.  RE: Clearpass Sponsor - Set expiry date when aproving Guest
    Posted Mar 20, 2015 07:30 AM
    Thanks a lot!
