last person joined: 10 hours ago
Clearpass Sponsored Guest access with specific AD groups
This thread has been viewed 16 times
  • 1.  Clearpass Sponsored Guest access with specific AD groups
    Posted Oct 20, 2021 07:24 AM
    Hi all,
    I've setup guest access with sponsor approval but our customer want to limit the number of sponsors with an AD security group.
    Is this possible?
    Kind regards,
    Thomas Willems
  • 2.  RE: Clearpass Sponsored Guest access with specific AD groups
    MVP GURU
    Posted Oct 20, 2021 09:26 AM
    You can edit the Guest Operator Login service to assign operator privilege. You can assign the AD group you want top use a role, and match on that to enforce a gest operator role. The "admin-privileges" value will translate to what operator role in clearpass guest they will get.
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: Clearpass Sponsored Guest access with specific AD groups
    Posted Oct 20, 2021 09:33 AM
    That is 1 step, but in the guest portal the guest gets a dropdown for choosing his sponsor.
    Is there a way to limit this?
    Kind regards,
    Thomas Willems
  • 4.  RE: Clearpass Sponsored Guest access with specific AD groups
    MVP GURU
    Posted Oct 20, 2021 09:35 AM
    If your looking to limit the names that show up for a sponsor search in your registration form, see below for where to apply an LDAP filter for the lookup. You can use a filter like the one below to help only list the group you want to show up:
      (objectClass=user)
      (objectCategory=person)
        # Match users in any of these groups
        (memberOf=CN=Group1,OU=ou-name,DC=domain,DC=com)
        (memberOf=CN=Group2,OU=ou-name,DC=domain,DC=com)
        (memberOf=CN=Group3,OU=ou-name,DC=domain,DC=com)
        # Match users by any of these criteria
        (sAMAccountName=*@SEARCH@*)
        (displayName=*@SEARCH@*)
        (cn=*@SEARCH@*)
        (sn=*@SEARCH@*)
        (givenName=*@SEARCH@*)
    Dustin Burns
