Clearpass SQL API
  • 1.  Clearpass SQL API
    Posted Feb 03, 2014 04:48 AM
    I want to use Guestaccount information from SQL API because the reports from Insight are only send by email as pdf.
    We want to do the billing automatically for our guestaccounts. We want to creat a process which directly connects to the sql api.
    I got access to the sql api via pgAdmin. But I don't find the table which contains the data i need.
    Where do i find the guest account data like
    username, sponsorname start date and expiry date?
    Is there any documentation about the sql api?
    Thanks a lot.
  • 2.  RE: Clearpass SQL API
  • 3.  RE: Clearpass SQL API
    Posted Apr 29, 2014 07:36 AM
    how did you connect to the SQL service with pgAdmin?
  • 4.  RE: Clearpass SQL API
    Posted Apr 29, 2014 08:06 AM
    Set the appexternal password under cluster settings and use those credentials to connect.
