Clearpass subscriber join failed
This thread has been viewed 33 times
  • 1.  Clearpass subscriber join failed
    Posted Jul 03, 2019 09:52 AM
    Hello Airheads,
    I am trying to join cppm subscriber node  to publlisher. Both running on same version, NTP, same subnet, valid license. No port blocking between two IP's. But i am getting following error:
    Ping:
    any clue?
  • 2.  RE: Clearpass subscriber join failed
    Posted Jul 03, 2019 09:54 AM
    Do you have a firewall between the Pub and Sub ?
    If so make sure the following ports are allowed between the two nodes:
    https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/What-are-the-ports-that-need-to-be-opened-on-the-network/ta-p/175872
    What version are you running ?
    Sent from Mail for Windows 10
  • 3.  RE: Clearpass subscriber join failed
    Posted Jul 04, 2019 12:35 AM
    I'm running on 6.8.0.109592.
    No port blocking in firewall. Both VM's connected to same switch
  • 4.  RE: Clearpass subscriber join failed
    Posted Jul 04, 2019 01:03 AM
    Need to update the DB cert and include ip address in the SAN field.
    IP:xxx.xxx.xxx.xxx
    I believe there should have been something put in the release notes but im not positive.
  • 5.  RE: Clearpass subscriber join failed
    Posted Nov 26, 2019 07:42 AM
    I ran into the same issue with 6.8.0.109592 on a new L3 cluster over ipsecVPN.
    Both CPPM's where using the self signed cert.
    I created a new HTTPS server certificate signed by the internal domain-CA for both an added the domain-CA cert as trusted root. Afther this, the cluster was formed.
    P.S. I also included the CPPM IP in the SAN field of the CSR.
