ClearPass Subscription ID
This thread has been viewed 30 times
  • 1.  ClearPass Subscription ID
    Posted Dec 23, 2013 12:02 PM
    The ClearPass event viewer starts today logging the message "Your subscription has expired, so you can no longer receive updates."
    Is the ClearPass Subscription ID valid for a period of time? Where can I check that on ClearPass?
    Thank you.
  • 2.  RE: ClearPass Subscription ID
    Posted Dec 23, 2013 01:09 PM
    Is that an evaluation subscription ?
    Or did you purchased this to be valid for certain amount of time ?
  • 3.  RE: ClearPass Subscription ID
    Posted Dec 23, 2013 01:25 PM
    Hi Victor,
    This is a valid license purchased last year with ClearPass via our reseller.
    Thanks for the response.
  • 4.  RE: ClearPass Subscription ID
    Posted Dec 23, 2013 01:44 PM
    Check admnistration ---> licensing
  • 5.  RE: ClearPass Subscription ID
    Posted Dec 23, 2013 02:08 PM
    In Agents and Software Updates -> Software Updates -> Subscription ID , is the only place where I can see my subscription ID.
    CPPM 6.0.1.
    Thanks.
  • 6.  RE: ClearPass Subscription ID
    Posted Dec 23, 2013 05:00 PM
    Take a look at the licenses in the Admintration area...what does it say in there?
  • 7.  RE: ClearPass Subscription ID
    Posted Dec 24, 2013 08:55 AM
    I have in the License Summary tab:
    Policy Manager: 5000
    OnGuard: 0
    Guest: 100
    Onboard: 0
    ClearPass Enterprise: 25
    In the Servers tab
    Policy Manager / Permanent / 5000 / Activated
    In the the Applications tab
    Guest / Permanent / 100 / Activated
    Thanks.
  • 8.  RE: ClearPass Subscription ID
    Posted Dec 24, 2013 08:57 AM
    Sorry - the subscription ID is valid for as long as your support is valid on Clearpass.  Is your support renewal getting close?
  • 9.  RE: ClearPass Subscription ID
    Posted Dec 24, 2013 08:59 AM
    Please contact support and verify your sub ID and your support contract.
  • 10.  RE: ClearPass Subscription ID
    Posted Dec 24, 2013 09:42 AM
    Thanks to all of you for your support.
    I contacted the support my ClearPass contract support was expired. Problem fixed.
  • 11.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 03:18 PM
    we have upgraded from amigopod hw to clearpass guest, and we have imported all configuration and added all the license, but when we check for updates , we get error msg your subscription id has expired, our support still valid,
    and i have a problem with my authentication between controller and clearpass,
    any advice
    thank you
  • 12.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 03:21 PM
    Please contact TAC on the sub ID.
    Can you do a test auth between the controller and CPPM.
    Double check shared secret on CPPM and the controller
  • 13.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 03:28 PM
    hi,,
    each time am tryin to test i got auth fail,
    i have checked the secret key betwwen them and the ip add and the port,
    for subscription id they gimme the same subscription id but it doesnt work,
  • 14.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 03:30 PM
    Are you seeing the auth request in cppm
  • 15.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 03:33 PM
    yes, on the clearpass i can see radius communication , and i got authentication failedon cppm on monitorin tab with that username and password
  • 16.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 03:34 PM
    i got reject msg
  • 17.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 03:40 PM
    In that service what is the auth source?
    Are you authenticating to AD?
    What are your settings for the enforcement?
  • 18.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 03:44 PM
    there is no AD, they are guest clients,
     we have controller and on the controller we assigned cppm as radius server ,
    and on the clearpass we added arubacontroller as a nac,
    should i create an enformcent for it?
  • 19.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 03:48 PM
    Yes you must create an enforcement. You can use the "guest Mac authentication" in the start here section in CPPM
  • 20.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 03:49 PM
    Did you use the service templates to create your services?
  • 21.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 03:53 PM
    but before i create the enforcment , i should be able to test auth from controller to radius ,right?
  • 22.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 04:01 PM
    If you have the correct service being hit and the auth method is correct.
    Is your guest account that you created active?
  • 23.  RE: ClearPass Subscription ID
    Posted Jul 08, 2014 07:47 PM
    re the subscription id, i had a similar case where even though support was valid, it hadn't been linked to the licensing system and i had to escalate through the TAC to have it resolved. Once i found the right person it was taken care of in minutes.
  • 24.  RE: ClearPass Subscription ID
    MVP
    Posted Sep 22, 2014 12:11 PM
    If your subscription ID expired, but then was renewed, how do you re-apply it? Does re-applying it require a reboot?
  • 25.  RE: ClearPass Subscription ID
    Posted Sep 22, 2014 12:13 PM
    You shouldn't have to do anything. Try re-checking for updates.
    Applying a subscription ID does not require a reboot.
