ClearPass Supported switches
This thread has been viewed 32 times
  • 1.  ClearPass Supported switches
    Posted Jul 07, 2021 10:36 AM
    i am looking to find a list of switches that support integration with clearPass.
    I am unable to find in the documentation.
    Kind regards.
    Ndricim
    Ndricim Danaj
  • 2.  RE: ClearPass Supported switches
    Posted Jul 07, 2021 11:33 AM
    I'm not aware of such a list, as it would be obsolete once it is published.
    A good start is the wired enforcement guide, with configuration guidelines for many of the big switch vendors (get it from www.arubanetworks.com/clearpassdocs). But I have seen many different brands and types of switches supported as well. ClearPass is all standards based, so if you have a switch that adheres to the industry standards, and you can configure them for RADIUS/802.1X/MAC-Authentication/TACACS+(Admin), you are probably good to go. But as the list would be too long, I have not seen such.
    Are there specific switches that you need to know the support for? People reading here may share their experience.
  • 3.  RE: ClearPass Supported switches
    Posted Jul 08, 2021 04:30 AM
    Hello Herman
    i want to thank you for your reply.
    There is a list of switches i am trying to find out.
    Here it is :
    WS-C2960S-24TS-S
    WS-C2960G-48TC-L
    WS-C3750-48P
    J9729A 2920-48G-POE+
    Cisco SF 110-24
    Mikrotik CSS326-24G 2S+RM
    Mikrotik CSR326-24G 2S+RM
    Netgear GS 724T Prosafe
    Zyxel GS 1920-24-hp
    TPLINK TLS SF 1024D
    TPLINK TLS SF 1008D
    Ndricim Danaj
  • 4.  RE: ClearPass Supported switches
    Posted Jul 13, 2021 01:40 AM
    Hi
    For Cisco, i'm using the series 2960X, 3850 and 9300 with Clearpass.
    Its up to you if want to integrate  EoL Cisco Hardware with Clearpass. In case of problems, Cisco TAC will not help.
    Best regards,
    Andy
    Andreas Odermatt
  • 5.  RE: ClearPass Supported switches
    MVP EXPERT
    Posted Jul 13, 2021 08:40 AM
    Hi Andreas,
    The HPE/Aruba 2920 is supported for standard RADIUS authentication.
    In fact all switches that support 802.1x and use the RADIUS:IETF basics are working with  ClearPass. Switches that are not have 802.1x support can optional work via SNMP ClearPass OnConnect, but i never used that functionality.
    Marcel Koedijk | MVP Guru 2021 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opionions are my own
