last person joined: 10 hours ago
ClearPass Syslog Export Filter Update Frequency
  • 1.  ClearPass Syslog Export Filter Update Frequency
    Posted Apr 20, 2016 03:25 PM
    We're using Syslog Export Filters to keep track of user login attempts in order to build an Access Tracker-like tool that also interfaces with some of our other systems. The tool is up and running and works pretty well but unfortunately ClearPass seems to hold requests for about 2 minutes before sending them all in a large batch.
    Is there any way to change how often it sends the requests? It would be beneficial if our tool could be updated more frequently.
    Thanks!
  • 2.  RE: ClearPass Syslog Export Filter Update Frequency
    Posted Apr 20, 2016 04:31 PM
    This is a limitation of the batching today of the syslog export, its not real-time. We have had a number of conversations to reduce the batch window but no immediate plans.
  • 3.  RE: ClearPass Syslog Export Filter Update Frequency
    Posted Apr 20, 2016 05:06 PM
    Hi Danny,
    Thank you for the quick response even though it's not the answer I was hoping to get. Is there any other way of retrieving login attempts from CPPM? And what is keeping Aruba from making the batching window configurable?
    Thanks!
  • 4.  RE: ClearPass Syslog Export Filter Update Frequency
    Posted Apr 21, 2016 04:18 AM
    Authentication logging goes through the database, which facilitates centralized logging in cluster environments, however makes real-time syslog events somewhat challenging and requires fundamental changes in the way how logging is implemented. The log viewer in the product is real-time.
    Please ask your partner, or if you are a partner to go to the idea portal in the Partner Center to add your specific requirements to the idea with the name: "ClearPass sent all events to external syslog immediately".
